Latest post 01-09-2010 11:23 AM by juanherrero. 8 replies.
Page 1 of 1 (9 items)
  • 01-08-2010 3:26 PM
    BeoMedia feigning death
    I have a BeoMedia box (connected to BeoCenter2 and BV7-40), which I haven't used for a while. When I pressed "List - PC", the BV7-40 came up with a blank black screen and hummed gently. I took the usual first step and powered everything off and back on again (BV7-40, BeoCenter 2, BeoMedia). Now when I press "List - PC", the BV7-40 still comes up with a black screen but now buzzes like a demented hornet. The little green light at the back of the BeoMedia box is blinking permanently. I pressed the sprung button on the back of the BeoMedia but it does nothing. Any ideas please?
    Juan Herrero
  • 01-08-2010 4:06 PM In reply to
    Re: BeoMedia feigning death
    Try to reboot Beomedia only
    -Dimitris
  • 01-08-2010 4:28 PM In reply to
    Isn't that what the sprung button on the back of the BeoMedia is supposed to do?
    Juan Herrero
  • 01-08-2010 4:45 PM In reply to
    Keep it pressed until the green light goes off. Then press it again to reboot.
    -Dimitris
  • 01-08-2010 6:03 PM In reply to
    Thanks. Kept button pressed for a long time - green light just keeps flickering. Switched off power - green light goes out. Power on - green light flickers constantly.
    Juan Herrero
  • 01-09-2010 3:56 AM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    It might be the powersupply, it´s an known issue.
    They just don´t give the right power after some time.
    Me and a few members have changed ours.
    Ask your dealer for a spare one, or buy one at your local electronic shop.
    Just be sure to get the right polarization and voltage.
     BV10
  • 01-09-2010 5:09 AM In reply to
  • 01-09-2010 5:27 AM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Sounds like your powersupply is end of it's life. Your local shop should be able to provide assistance.
  • 01-09-2010 11:23 AM In reply to
    Thank you, all!
    Juan Herrero
