Latest post 01-30-2012 2:33 PM by mbee. 249 replies.
Page 1 of 10 (250 items) 1 2 3 4 5 Next > ... Last »
  • 01-06-2010 5:48 AM
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    The unique, one and only SOFTWARE UPDATE THREAD!
    Happy new year everybody!
    I'm starting this new thread to fill a gap in beoworld : there is no page with informations about the latest software version available for all B&O common platforms that are updated frequently : BS3, BV8 and BS5.
    We could update this thread each time a new software is released with the full changelog (so you can see what things have changed for your specific products. I'm writing here the changelog for the common BS3/BV8 and BS5 softwares, you can complete it with past releases and give me the correct software n# for current versions (I don't know what's the latest software n# for BV8 and BS5). Maybe I should update this first post each time a new software is released.
    If someone has the changelog for BV8/10 DVB HD tuner (which is updated separately and can be done bu the user), it could be interesting to post it here also!
    I hope that this will help!Smile
    BS3 (valid for all BS3 based TVs)  Latest software : 10.05a
    (no changelog)
    SW 10.02 (build 814) - 11/2010 - Changelog :
     - Bugfixes
     - Possibility to deactivate center speaker
     - Fans start up delayed by 20s
    SW 9.01 (build 714) - 12/10/2010 - Changelog :
     - Sleep Timer(how it could take B&O 1 million years to implement that i dont know?) :)
     - "Game mode" under picture settings, don't know what it does.
     - New DVB-HD logo instead of that hideous clock screen
     - Fix for the dark screen issue?
     - Auto standby
    SW 8.12a (Build 632) 26/04/2010 - Changelog :
    Build 632 - Master Link delay and feature activation.
    New features
      1. Sound delay for sound on Master Link, elimination of echo when same source is used in main and link room.
         See also Master Link delay
      2. Possibility of naming individual sources, e.g. the source name “PC” can be changed to “MyMac”.
         The option is present on all sources connected to an AV connection, but not on built-in sources.
      3. Feature activation incl. support for HDMI video distribution.
      · Activation of this feature requires purchase of an activation key specific to the television set.
      · Distribution of HD signals via HDMI/CAT7 cables to link rooms using an HDMI Matrix (third-party equipment).
      · Can ONLY be controlled by Beo5. Special template is being developed.
      4. Setup option for Beo4 Setting, only “no Navigation button” can be selected, feature is for future use.
    SW 8.02 (Build 551) - 03/2010
    (no changelog)
    SW 7.05 (Build 551) - 02/11/2009 :
    1. No menu, no overlay menu, no curtains (Build 548).
    2. Menus and OSD disappeared (Build 548).
    3. BeoSystem 3 freezes when receiving DTV+CINEMA_OFF from standby (Build 548).
    4. TV does not go into standby, and standby diode is blinking (slow flash) (Build 548).
    5. Intermittently the television switches off (Build 548).
    6. ACM crashes when source is YPbPr in High-Definition (was solved in Build 533) (Build 548).
    7. No volume bar after using EPG in DVB-HD (Build 548).
    8. Panel info says 50 Hz and not 100 Hz (Build 548).
    9. No link control of DTV source (STB), if main room television is in standby (was solved in Build 533).
    10. Lip-sync on Blu-ray does not match.
    11. Timer on DTV-RADIO. Turn on to last shown TV (DTV) channel when link TV is connected.
    12. Non B&O screen: Screen switches on when switching off from audio mode.
    13. Not correct channel is showed when Play timer from another favourites list is programmed.
    14. Difference in sound level between DVB picture and DVB Full-text.
    15. Different issues with opening and closing curtains (half open-half closed).
    16. Mixed sound from Radio and DVD in link room.
    17. Stand does not always turn to stored positions.
    Note : This update adds a bug on BV7 which makes the fan too much audible... Next update : 7.11, soon!
    BV8 40 SW (valid for BV8 40, BV10 40, BV7 32mkV, BV6 26 mkII) latest Build : 210 - 9/2011
    (no Changelog)
    Build 165 - 2/2011 (no changelog)
    Build 155 - 1/2011 (no changelog)
    Build 153 - 10/2010 - Changelog :
     - Low picture/menu quality on DVB-HD
     - A loud ticking noise is heard when stepping up/down on Humax 5050/5000 set-top box
     - The previous factory Build 126 had issues resolved by this update
     - After a period of time there is no set-top box IR-control
     - Incorrect translation from DVB-HD
    Build 127 - 5/07/2010  -Changelog :
     - Fixes the DVB-HD blocking problem of build 126 (if Radio and then standby was selected)
    Build 126 Release date 1-07-2010 (added a DVB-HD blocking problem if Radio and then standby was selected, updated by build 127)
     - Darker default picture on BV10 in order to lower visible clouding
     - Hideous timer logo removed from DVH-HD startup, replaced by a small B&O logo
     - Naming of sources can be personnalised by user (BV7-style)
    Version Build 109e Release date 26-04-2010 (no changelog)
    Version Build 109b. Release date 15-03-2010 (no changelog)
    Version Build 86b. Release date 28-10-2009, new Features :
    1. On-screen menus changed (black menus)
    2. Sleep timer function.
    3. You can add additional HDMI sources connecting an HDMI Expander to the HDMI B socket.
    4. Speaker mode 1 can be selected as standard setup in Video mode even if front and rear speakers are in the setup.
    5. If used with RS4 software or higher on DVB-HD, then MHEG is possible in UK.
    DVB HD (MKI/MKII) module (found on BV7, BV8 and BV10)
    This software update can be done by the user : download it here : http://www.bang-olufsen.com/dvb-hd/software-downloads
    Latest version : 0.1.8.9.0 - 11/2011 - Changelog :
     - Semitransparent EPG + bug corrections
    0.1.7.1.0 - 7/2011
    0.1.6.5.0 - 3/2011
    0.1.4.7.0 - 11/06/2010
    0.1.4.5.0 - 12/05/2010
    BV7-32/TYPE 9312/MKII : Latest Software : 6.33
    BeoCenter 6-23MKII/26 (Type 9219-9226, 9280-9287)
    Latest Software 10.10A
    BS5  SW 6.05.01.3357
    Support of Apple Lossless files!!
    Possibility to rip at MP3/320kbps with CD Ripping device instead of WMA Lossless (for compatibility with iDevices)
    SW 6.05 - 12/2011
    2-way mode for Beo6
    Ripping device support
    SW 6.01 - 2/06/2010
    MOTS features
      ·  Exclude from MOTS
      ·  Exclude from previous album
      ·  Disable MOTS
      ·  MOTS status + progress bar
      ·  MOTS logo
      ·  MOTS button on Beo4 (1710)
    System functionality
      ·  BeoSound 5 placement in link rooms
      ·  BeoSound 5 in option 1.1 and 2.2
      ·  BeoVision 8-40, 10-40 and 10-46 compatibility
      ·  Master Link Gateway compatibility
      ·  Support for older televisions / IR compatibility
      ·  Play Timer (on/off)
      ·  More than one BeoSound 5/BeoMaster 5 in a setup
    Other refinements
      ·  OS updated to version 6.01
      ·  Performance at start-up improved
      ·  Password in user service menu
      ·  Show share & user name in NETWORK INFO
      ·  New setting for N.Radio buffer length
      ·  New setting for adjustable start time in N.Music
      ·  ABOUT box introduced
      ·  Driver for Bang & Olufsen approved wireless adaptor GN-WB31N is
         incorporated
      ·  Flash Player 10 support
      ·  Status on Bonjour
      ·  Support for Russian (Cyrillic) character set
      ·  Improved internal logging for debugging purposes – for instance logging
         of received and issued Master-link commands
    SW 5.03 -18/01/2010
    Added : the BM5 can now display content to a link room TV !
    Beosound 4 SW 2.15/1.31c - 7/12/2009, New functionality on A. MEM, new Features :
    1. Compatibility with SDHC card (High Capacity SD cards 4 GB to 16 GB)
    2. Ability to start recording from remote control
    3. Ability to copy only selected tracks from a CD to the SD card
    4. The ability to make timer recording on SD card
    5. Ability to fast forward and back when playing from SD card
    6. Resume playback from the SD card after source change or turn off
    7. Compatibility with Master Link Gateway (redirection of light and control commands)
    Beo5/Beo6 :
    Latest config tool : 5.12
    Latest Beo5 firmware version :1.45b
    Latest Beo6 firmware version : 2.11a
    Config tool 5.12 :
     - Support for 2-way mode for Beo6+Beosound 5
    Config tool 4.11 :
    - Support for Beo6
    Config tool 3.87 :
    - Load previous local versions (going back to a working config)
    - Support for new Beo4 (type 1710) w. cursor control
    - Drag and drop of template logos
    - more than 200 PUC-Sources updated with cursor control
    - PUC-Sources are sorted by type and manufacturer
    - Correct channel step inside channels menu
    - Navigate to "Zones"
    - Navigate to "Setup mode"
    - Updated "Help"
    & some bug fixes
    Config tool 3.59 :
    Bug fix from 3.57
    Config Tool 3.57 :
    Firmware 1.45a
    - Battery drain bug corrected
    Firmware 1.42a
    BeoVision 7-55 added
    BeoVision 10-40 added
    BeoVision 8-40 DTV2 update
    Logo templates for Norway
    BeoSound 5 - RADIO and CD
    Config Tool 3.23 :
    Beovision 6 26 changed
    Beovision 4 103EU added
    Config tool 3.00 :
    New installation
  • 01-06-2010 6:36 AM In reply to
    • Spiros
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: The unique, one and only SOFTWARE UPDATE THREAD!
    Very nice initiative!!!
    Maybe some other products could be added as well!
    Best regards
    Spiros
  • 01-06-2010 6:57 AM In reply to
    mbee:
    Beo5 :
    Latest config tool : 3.23
    Latest software version : ???
    Lastest firmware: 1.41e
    /Frank
  • 01-06-2010 8:33 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    thanks Frank, that's updated!
    Now we have to go to the archives of Beoworld in order to find changelogs...
  • 01-06-2010 10:51 AM In reply to
    How can i see the version of my BS3??
    Great initiative,
  • 01-06-2010 10:59 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    If I remember correctly, on all recent stuff, you just have to be in the main menu and press 0 0 Go...
  • 01-06-2010 11:41 AM In reply to
    • Teletom
    • Top 500 Contributor
    • Joined on 05-09-2007
    • the Netherlands
    • Posts 111
    • Gold Member
    Hi mbee,
    I very much welcome your initiative!! Information about B&O software updates, both sw number and functional changes, has always been very high on my wishlist. So if you can manage to update us on a regular base it will certainly be highly appreciated.
    Johan
    WOW
    this a MENU new to me,is this the correct page?Sorry it's specular!i used my macbook built-in camera
    there  a lot of voices i don't understand like
    DVF enabled?
    and on picture setting:AGC,COMB FILTER,
    SOUND DELAY?set to 110
    WSS STATUTS?(on teletext adjustamnet)
    M2 information  01.00a
    m2boot 01.00a    (what stand for??)
    B&O should do a manual to help consumers!
    P.S:why i have a lot of tv'errors?
  • 01-06-2010 12:21 PM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Andreabang : don't try to change anything in that menu, it's the service menu, not a customer-level menu... So if you don't understand, don't touch!
    The only thing interesting for you is your software n#
    Teletom : I don't receive information about each B&O software update : sometimes I can get ones from my dealer, sometimes from Beoworld... It's a public thread, so everyone with informations about SW can help!
  • 01-06-2010 5:55 PM In reply to
    And ...
    Beosound 4
    New Features
    Technical Information
    Software 2.15/1.31c, New functionality on A. MEM
    Information valid for: BeoSound 4
    Last modified: 07-12-2009 10:21:06
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-07-2010 4:16 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Thanks Elephant, added! Big Smile
  • 01-07-2010 12:19 PM In reply to
    mbee:
    BS3 (valid for all BS3 based TVs) SW 7.05 (Build 551) - 02/11/2009 :
    Great idear
    I have been missing this for a while :-)
    I unfortunately have to add, that 7.05 also speeds up the fans with dramatically increased fannoise as a result. (at least on 7-40 MK IV)
    Dont know if the updates are intended to be discussed here, or only presented ? If the latter is the case, i apologize :-)
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 01-08-2010 4:40 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Is there any chance that this can be pinned?
    I assume it will be very interesting for everybody eventually
    Best regards
    Spiros
  • 01-19-2010 2:21 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Spiros : good idea, but pinning a thread is a moderator's choice...
    By the way : I updated the BS5 part with yesterday's software update. If someone can give the full changelog, it would be perfect!
  • 01-25-2010 7:14 PM In reply to
    A 7.11 version is coming for Beosystem-3 based TVs. Apparently, the fan issue is fixed according to some "beta testers" from the Beoworld Scandinavian forum.
    Regards,
    Jean
  • 01-25-2010 8:55 PM In reply to
    This post is a very good idea !!!
    For BV7-32/TYPE 9312/MKII/
    Latest Software is software version is 6.33 with a part number of 8344431. No idea about the improvment made by this software but it should make the TV HdReady.
    Source: http://forum.beoworld.org/forums/t/31530.aspx
    Mat
  • 01-26-2010 12:35 PM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    @matbkk : added!
  • 01-26-2010 1:02 PM In reply to
    A huge DVB-HD module update will be available in week 14, It should deal with missing EPG information etc.
    /Ehlerz
  • 01-27-2010 1:19 AM In reply to
    • HeKoch
    • Not Ranked
    • Joined on 09-29-2008
    • VS-Schwenningen /Germany
    • Posts 46
    Will that eliminate our evil with the creeping EPG ?
    HeKoch
  • 01-27-2010 5:36 AM In reply to
    Hopefully this discussion will get pinned.
    7.11 is hopefully a significant release. I'm hoping for fixes to the fan issue, resolution of picture quality degradation with 7.05 in both SD and HD versus 6.xx and bug fixes to Blu-Ray drive. I've gone back to 6.11 currently as 7.05 was totally unacceptable and our B&O engineer felt more comfortable with it due to other customer issues he had seen.
  • 01-27-2010 5:39 AM In reply to
    HeKoch:
    HeKoch
    Hi HeKoch
    So i was told by my dealer who has been in contact with the  B&O tecdepartment multiple times since i told him about the problems i had.
    But then again, i have been disappointed with the latest softwareupdates, so i guess we just have to wait and see. If it is anything like SW 7.05, we will probably experience some brand new issues like flames coming out of the cabinets or what do i know :-)
    /Ehlerz
  • 01-27-2010 5:40 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Waow, it seems that there are some very well informed guys here that already knows the changelog of future updates due in 10 weeks! Great!!
    Does somebody knows if the DVB HD "big update" of week 14 will speed up this module (which is very slow...)
    Any news about an upcoming BV8/10 platform update?
  • 01-27-2010 6:27 AM In reply to
    mbee:
    Hi Mbee
    I dont know that but like you i hope for massive improvements. However, my experience tells me not to get my hopes up, remember that SW 7.05 passed the quality test (???), and so did the latest DVB-HD updates. B&O are NOT very good at this, and even though we will probably see improvements on some issues, there will undoubtedly be other and new issues. And then we will have to wait ANOTHER 6 months.
    Lets hope that this update is THE ONE that proves me wrong :-)
    /Ehlerz
  • 02-24-2010 5:52 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    First post updated : new softwares for Beo5.
    News about this thread :
    -Unfortunately, it can not be pinned as there are too much topics pinned.
    -There is now a topic in the Beoworld FAQ pointing to this thread :
    http://www.beoworld.org/faq_view.asp?id=97
    If someone has informations concerning new software release for Beovisions/Beosounds, just tell me!
  • 03-19-2010 3:38 PM In reply to
    Version 8.02 for besystem3.Just installed,i don't know what's improved btw :)
