Latest post 01-06-2010 11:55 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 01-05-2010 9:49 AM
    RL 140 speakers replacement
    Bonjour,
    I need to replace a woofer and medium speaker on RL 140.
    Does anyone know exact specifications for these two speakers since I'm going to try to find new ones?
    Thanks for your help.
    Regards.
    Alain-Olivier.
    Filed under:
  • 01-05-2010 10:35 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: RL 140 speakers replacement
    If the foam surrounds have rotted and are falling apart, they can be repaired.
    If one shows rot, the other three will also be bad or at least marginal.
    If a woofer is no longer playing, it will most likely need replacing.
    The woofers are 6 ohms and will be hard to match with modern types.
    I have a set of original woofers, refoam'ed and ready.
    No midranges though.
  • 01-06-2010 4:59 AM In reply to
    Thanks for your answer Martin.
    Would you agree to let go of one woofer only as the other three are functionning and newly refoamed, and at what prize?
    Regards.
    Alain-Olivier.
  • 01-06-2010 11:55 AM In reply to
    • Dillen
    • Posts 5,008
    Sure, you have a PM (check your inbox at the extreme top right corner of this page).
