1st March February 2012
Latest post 01-04-2010 2:33 PM by frankmj. 15 replies.
01-04-2010 3:41 AM
frankmj
![](/utility/anonymous.gif)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-18-2007
- Denmark
- Posts 177
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
XML file for Sagem ITSD81 HD
I've changed to Canal Digital and need the file - anybody got one?
Thanks in advance
/Frank
Tillquist
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.36.32/avatar.jpg)
- Joined on 05-26-2007
- Denmark
- Posts 211
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
Re: XML file for Sagem ITSD81 HD
I am quite sure that it is in CT3.23.
But I look for when I come home again
My Bang & Olufsen....
- BeoCenter 2 DAB/DVD mk.II
- BeoVision 7-40 DVD mk.III
- BeoLab Penta mk.III
- BeoLab 4000 icepower
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beo 4 mk.I & mk.III
- Beocom 6000
- A8 Earphones
frankmj
- Denmark
- Posts 177
Yes it's there, but as a PUC source. I want it as a third party source.
/Frank
Keith Saunders
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.92/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Frank,
Click HERE for a Canal Digital XML for direct control from the Beo5. Hard keys and digits are pre-assigned in this XML file
frankmj
- Denmark
- Posts 177
Thanks a lot Keith!
I will try it right away.
Cheers
Frank
frankmj
- Denmark
- Posts 177
I'm sorry Keith, but it doesn't work with my Sagem. None of the buttons work.
The buttons text in the file doesn't match the remote buttons text for the ITSD81HD either.
/Frank
Keith Saunders
- Posts 3,810
Well, I guess the Canal Digital remote I created that file from is different from yours.
If you have the IR timings or can find the Pronto codes on the web, then send them to me and I will create a file for you.
frankmj
- Denmark
- Posts 177
Yes, it must be different. There's no Pronto codes i'm afraid, but maybe Weebyx can help?
/Frank
Keith Saunders
- Posts 3,810
Frank,
If you can use a Lintronic box to capture the codes, then a XML file can be produced.
frankmj
- Denmark
- Posts 177
I know Keith, Unfortunately I don't have a Lintronic box, and I think it's to expensive to buy for this one time job.
/Frank
Tillquist
- Denmark
- Posts 211
Hi Frank
It is in CT3.23 -> ThirdParties -> PUC Sources
You can download it here
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beocom 6000
- A8 Earphones
guffas
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.18.95/avatar.jpg)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 03-21-2009
- Posts 56
The correct PUC filename for this box is: Sagem_STB_HD81svensk_V01.00a.dec
Keith can you create the XML from the DEC files?
Keith Saunders
- Posts 3,810
guffas:Keith can you create the XML from the DEC files?
I can create a Beo5 XML file from any PUC DEC file...
frankmj
- Denmark
- Posts 177
Tillquist:
Hi Frank
It's the PUC file, I need it as a direct third party file, so I can control the box directly, not via the PUC.
/Frank
Tillquist
- Denmark
- Posts 211
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beocom 6000
- A8 Earphones
frankmj
- Denmark
- Posts 177
Tillquist:
What is it? I compared the file with the one in the CT 3.23 and they are exactly the same. For use with beo4/beo5 to operate the box via PUC. Not what I am looking for. The PUC software is very unstable, I have to reset the box (and TV) very often. Never any problem with direct control.
/Frank
Page 1 of 1 (16 items)
