I have been using Beolink Wireless for more than 12 months, and I have been disappointed because I get intermittent drop-outs.
The causes of these drop-outs appear to be varied:
- use of our microwave almost always interrupts the Beolink Wireless transmission
- sometimes electric trains passing by our house will interrupt transmission
- rain appears to make the interruptions more likely
Note these are based my observations/suppositions rather than proven scientific facts.
My dealer was very helpful - loaning me units until we got the 4 units (one transmitter, three receivers) that worked together (an issue of getting the Beolink Wireless software levels to match); one the less overall the technology does not work within my environment.
Apart from the microwave and trains as sources of interference I had a wireless LAN, an Apple Airport Express for additional music, and Beocom 6000 DECT transmissions - so without some or all of these factors the system may work for you.
I recommend that you get two loan units from your dealer and do some exhaustive tests.
And yes, the IR eye is needed on the Beolink Wireless receivers, but not the transmitter; note that each Beolink Wireless unit has a switch that makes it either a transmitter or a receiver.
My plan is to switch in 2010 to a wired network (probably CAT7) and Beolink Actives.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
