Latest post 01-03-2010 2:04 AM by ONFIRE. 2 replies.
Page 1 of 1 (3 items)
  • 01-02-2010 7:37 PM
    • ONFIRE
    • Not Ranked
    • Joined on 01-03-2010
    • Posts 2
    BeoSound6 - MAC: iTunes: BeoSound 6 plug-in
    I am having problems locating this plug-in for Itunes.  Having searching the Internet for hours I kinda gving up!
    Help! Can anyone tell me where I can locate the MAC: iTunes: BeoSound 6 plug-in?
  • 01-03-2010 1:28 AM In reply to
    Re: BeoSound6 - MAC: iTunes: BeoSound 6 plug-in
    there was a recent post advising to use Max OSX's Finder for managing the BeoSound 2 because the BS2/iTunes interface broke with the arrival of iTunes 9 ... perhaps you can/should use the same technique ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-03-2010 2:04 AM In reply to
    • ONFIRE
    • Not Ranked
    • Posts 2
    I understand the technique as described http://forum.beoworld.org/forums/p/30941/248278.aspx#248278
    But I require the BEOSOUND 6 Device to be seen within Itunes, which is possiable with the iTunes: BeoSound 6 plug-in
    Thank's
