Latest post 01-30-2010 8:03 AM by frankmj. 4 replies.
Page 1 of 1 (5 items)
  • 01-02-2010 6:09 PM
    How to create XML files from pronto codes nowadays?
    Hi to all!!
    As far I know, the last version of Lintronic Configurator is not compatible with Keith's XML generator 1.1. So what shall we do now? Are there some way to generate XML files from pronto codes?
    I will strong appreciate some help. Thanks!
  • 01-04-2010 7:42 AM In reply to
    Re: How to create XML files from pronto codes nowadays?
    An XML file can be generated from Pronto Hex codes without problems, but not with the XML generator.
    If you upload HERE a ZIP file with a file of all the Pronto codes which need converting, I will return you a file.
    Regards Keith....
  • 01-13-2010 5:19 AM In reply to
    If anybody got a version of the "old" Lintronic Configurator v.1, we could use the Code Learn section without a Lintronic box, to convert the pronto codes to something usefull.
    Anyone ?!?
    /Frank
  • 01-30-2010 7:57 AM In reply to
    frankmj:
    Anyone ?!?
    /Frank
    An older version of the Lintronic Software can be found here.
    Cheers,
    Frank
  • 01-30-2010 8:03 AM In reply to
    Great! Thank you.
    /Frank
