Platter pattern okay, as per SM. I'm confused. I also checked the three transistors that amplify and shape the signal. The cap (C15) is new. What about the carriage motor sensor counter then? Does this fail? Does it send any information to the processor that could be related to my problem?
The platter will turn forever in pause mode (33 or 45), but it will stop in play mode after 30 seconds.
By the way, I think the 6006 and the 8000 a similar but different animals.
First, the carriage shaft motor is different, the pulley is bigger on the 6006, and the motors sound different.
The PCBs are different too on my examples, it is difficult to follow a diagram on the SM!
Next, the suspensions are set differently: on my 6006 it will bounce nicely with the platter 1.5 mm above the plinth, as on my 8000 it will have to be level with the plinth (actually both seem to exist when you google BG pictures!). On the 6006, the arm moves quickly and decidedly; on the 8000 it seems as if it takes its time sensing the beginning of the record, then settles nicely. For what it's worth anyway.
Once again, happy New Year to Beoworld members!
