Latest post 01-04-2010 11:18 AM by Pendragon. 2 replies.
Page 1 of 1 (3 items)
  • 01-02-2010 7:21 AM
    • Pendragon
    • Not Ranked
    • Joined on 01-25-2009
    • Potters Bar - Herts
    • Posts 8
    Connecting Belolab 6000's to a Samsung LED TV
    My Avant has finally given up the the ghost and I have now replaced it with Samsung LED TV. I would like to connect my Beo Lab 6000's to them. Is this possible. I still have my Overture Hifi & Beo 4 remote. Any advice would be highly appreciated. Happy New year
    Filed under:
  • 01-02-2010 4:40 PM In reply to
    Re: Connecting Belolab 6000's to a Samsung LED TV
    Beolab 6000s have both a powerlink and traditional LINE input sockets.
    But it depends on what your Samsung outputs its audio signals as; if the Samsung supports traditional passive speakers DO NOT connect the beolabs.
    What model is your Samsung, where does it get its video signals from (e.g. where is the DVD, Blu-Ray, Set Top Boxes, whatever) in your setup.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-04-2010 11:18 AM In reply to
    • Pendragon
    • Not Ranked
    • Posts 8
    Hi Thank you so much for your reply. I have a Samsung LED UE32B7020 . The tv has a Digital Audio Out(Optical). Tv chanells are direct from tv(no box) DVD (not hd)  player  is connected thru Component Link.
    Thanks,Caan
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
