1st March February 2012
Latest post 01-16-2012 12:28 PM by Søren Mexico. 21 replies.
01-02-2010 12:22 AM
KevRC4130
- Joined on 01-02-2010
- Posts 5
Beomaster 2400 - No bass/treble lights
Hey everyone,
I'm the proud owner of a Beomaster 2400. It works flawlessly, except for one thing... The bass/treble lights do not work (though the bass and treble functions do work). The balance light, however, does work. Any ideas about a fix?
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beomaster 2400 - No bass/treble lights
You just need to replace the bulbs. The sliders actually move plastic films in front of a bulb - not as high tech as it looks! These are not the simplest machines to take apart as there is a lot fitted into a small box! If you have done similar work before, it is quite simple but I would get someone else to do it if I were a novice!
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Welcome to Beoworld !
I agree with Peter. A lamp kit is available and it comes with detailed (dis-)/assembly instructions but the lamps are soldered in boards which means that basic soldering- and electronic skills and tools are required. If you don't feel up to the job yourself, grab a lamp kit and bring it with the Beomaster to your local repairer. If a few lamps are out, the rest will be marginal too and their filaments will be brittle. The unavoidable vibrations from servicing and handling of the boards will break more filaments so I suggest replacing them all in one go. That will give a fresh life-span to them all and also provide an equal light output.
KevRC4130
- Posts 5
Thanks guys! I was hoping it would be something as simple as the bulb.
I don't have much experience taking apart electronic units like this, but I am pretty handy with a soldering iron, so I think I'd give it a whirl. Where can I find these lighting kits? Approx how much should I expect to pay? Are there any online guides that I can follow before buying (maybe a wire just needs to be re-soldered, for example).
Thanks again! :)
Dillen
- Posts 5,008
You have a PM, check your inbox at the extreme top right corner of this page.
mormel
- Joined on 07-27-2009
- Posts 51
The lampsbulbs used are 12V/30mA diameter 5mm / lenght 11mm. There are 15 of them.
I couldn't find the right dimensions, but I used these one " http://shop.conrad.nl/elektronica-meetapparatuur/componenten/elektromechanische-componenten/gloeilampen-met-soldeeraansluiting/720118.html " instead and it works beautifuly (the metal clips are not tight anymore, so make sure they won't be able to get in contact with the lamps wires ;) ).
Soldering the is not a big issue. This was my first soldering project and I was done in 2 hours (excl putting together the machine again, that took me 2 hours as well ;) ).
Just PM me for questions if you want to know more.
Beogram 4000, 4002, 8000, 8002. Sorry, got rid of all the rest.
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
I did my BM2400 lamps with a kit from Dillen and they are all working fine now. The kit contains exactly the right size lamps so that the clips still function correctly, and this too was my first proper soldering project and I found the instructions supplied invaluable in helping me along the way :)
Dillen
- Posts 5,008
Unfortunately, 12V 30mA is stated in error in some early service manuals but does not correspond to what's factory mounted in the Beomasters. They will not give correct function to the tuning discriminator lights, typically leaving the two just lit up showing nothing at all and, since they don't provide the correct load on the 15V supply, they will in many cases cause the Beomaster to turn off by itself intermittently and/or make it hard or completely unwilling to go into standby or change to specific sources, depending on the general state of the rest of the Beomaster. B&O issued a tech note about this.
They will also give different light output since some of the Beomasters lamp circuits are balanced and current controlled where others are just supplied from a plain analogue source so it won't look as the designers intended.
I've had Beomasters sent to me for service where the only faults was that wrong wattage lamps or lamps of different wattage were mounted. The lamps mormel link to are cheap china types, not high quality long-life types and they will require replacing quite often. Some of the lamps in this series of Beomasters are living a fairly hard life and if the load on the supply is too light, which it will be if mounting lamps with too low wattage, the voltage will be too high and lamp life will be short. Plus they won't fit into the lamp holders, which again will allow them to vibrate ever so slightly and their filaments will become brittle in no time. People, who owned Beomasters through the 1970's and 80's, will remember that lamps were an everlasting head-ache, and that was because the owners bought the cheap lamps supplied by radioparts dealers instead of spending a little more and buy the correct and better ones from a B&O dealer.
I recommend you use long-life types only and of the correct wattage. Preferably types capable of handling a continous 15V DC, since many B&O lamps are slightly overrun and will stay lit for hours. The three balance/treble/bass lamps are always fully lit when the Beomaster is powered on and they form part of the electronic switch circuit, decharging the 15V secondary at switching off. Correct lamps can be hard to find and the typical cost is about EUR 3/each (a little cheaper if you buy 10.000 pcs.) but are, as J0hnbarker also suggests, available as a kit which also comes with instructions.
mormel
- Posts 51
You're probably right of course, but as I said, I have no strange behavour (even the tuning indicator is working fine) of the machine and the light intensity is simular to what I remembered as it should be. I don't use the 2400 on a daily bases, so I just needed a cheap quick fix and it just did the trick for me anyway, maybe I'm just lucky.. We'll see how long it will last :).
Dillen
- Posts 5,008
Well, the only references I have are the service manuals plus correction sheets and updates, 35 years of experience in collecting and servicing B&O audio stuff and the tech info sheets released from B&O to their authorized repairshops. Not much, I must admit.
You are happy, that's the most important thing.
mormel
- Posts 51
I don't doubt your integrity Martin. I think you're doing a great job offering people to help and repair their precious B&O machines.
I also understand that this is your business to sell/repair this stuff and therefore can't share everything you know (I don't mean you're not willing to help members out with questions and repairs). I would do the same thing if it was my business. I have my own steel construction plant and I won't learn just anyone to weld or tell them where I order my steel. That would me take out of my job.
This forum is helping me so now and then and you're helping me out as well of the things you write here. Thnx for the effort you make.
Bart
jgunzelman
- Joined on 04-17-2007
- Posts 10
I too bough the kit from Martin. It was my first electonics repair. Not only were the instructions invaluable, but when I got it back together and something was not right, he resonded to an email inquiry, was absolutley correct with the answer and I had it fixed in no time. Thanks again Martin!
Dillen
- Posts 5,008
Bart,
Sorry if I have left you with a wrong impression. I am not running a business, I don't have a shop and I am not making any money on the kits. That's what I have my 8-16 job for and that's not electronic related. The overhead of a kit is typically about one pound, made so simply because I can't justify to lose money - and that's not counting the trip to the postoffice. Check the cost of the correct types of lamps, often custom produced in small quantities, VAT, two times shipping, packing and eventual customs and you will see. The kits were put together for pure convenience. After answering the same questions and diagnosing the same faults over and over through many years, kits were put together and the owners told to simply grab a suitable one and it will solve their problem. This leaves me with more time for dealing with other issues and stubborn repairs.
People who had their stuff repaired here will also confirm that I am definitely not doing it for the sake of money. That would indeed be a bad business.  B&O was always a hobby for me. I would like to see all the old B&O stuff up and running and I especially like to dig into problem cases and items that were deamed hopeless by other repairers.
When I told you why you should get the correct lamps, it was merely out of pure knowledge and experience and to help you avoid some of the problems that I have seen myself. Even if it is 30 years or more ago, I still clearly remember mounting wrong lamps according to the service manual myself and afterwards wondering what was going on, until finally looking up the tech sheets. The cases are still to be found in my own red book of experience, written in capital letters. You are welcome to mount whatever you feel for. I have given you my best advice and will be happy to do so again, should the need arise.
mormel
- Posts 51
Very cool Martin, maybe I got the wrong impression indeed. Bad experiences with people who "know" B&O stuff after a while ;). Glad you cleared up the sky for me.
But as I said before.. It always was clear to me you're doing a great job helping out people :)
cheers
RHM
- Joined on 01-16-2012
- Posts 4
Hi
I realize this discussion is a bit old now, but could someone provide the details on how to buy the lamp kit with instructions? I have a Beomaster 2400 where the bass light is out.
Thanks.
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Welcome to the forum, where nothing gets old, the lamp kit you can buy from Martin (Dillen) here, if you did not make a cap change and check the trimmers, I recommend to order also a cap kit and check the trimmers and order these too.
I buy frequently from Martin and can recommend him, the kits arrives with clear instructions.
Martin, as a high count poster, has problems posting on the forum, I think we will have to wait for him until we get the forum on a new server, but mail him and you should be able to order.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
RHM
- Posts 4
Thanks for the fast and friendly reply. I went to the site you included in your answer, but all I could see was another forum page with some discussions about Dillen and nothing about ordering parts kits. I will look again, but does Dillen maintain his own web site for such orders?
Søren Mexico
- Mexico city
- Posts 1,621
Go to the link, on the left side look for options, choose "start a conservation with Dillen", a new window will open, there write your subject and text, click send, Martin will answer.
RHM
- Posts 4
Thanks, I did that. Does he maintain a separate web site for his parts orders, or is it always done through the forum, just as I have done?
Søren Mexico
- Mexico city
- Posts 1,621
RHM:
As far as I know, Martin does not have a website, he will contact you through the mail address you provided to the forum, you and him can then agree on other ways of corrosponding if you wish. I have another mail address for Martin, but do not know if he want that on the forum.
RHM
- Posts 4
Thanks. He did reply to me with instructions on how to order. Where do you live? Where does Martin live? I live in California, USA, near San Francixco.
Søren Mexico
- Mexico city
- Posts 1,621
If you look at our avatars on the left you can see our locations, I'm Mexico city Martin is Copenhagen
Page 1 of 1 (22 items)
