Latest post 01-02-2010 1:55 AM by strangeadam. 4 replies.
Page 1 of 1 (5 items)
  • 01-01-2010 1:26 PM
    beomaster 2400-2 no start
    i have a 2400-2 that does not start. the led is on and the power is working. I replaced the c92 cap and adjusted the15volt supply but no answer
    I have the solder , the screwdriver and passion
    Any help wellkome
    Filed under:
  • 01-01-2010 4:36 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beomaster 2400-2 no start
    Welcome to Beoworld !
    Is there no reaction at all when you touch a source pad ?
    - No click ?
    - No flashing lamps ?
  • 01-01-2010 5:45 PM In reply to
    when i try to start the ic responds with a change in voltage but it doesnt seem to hold.
    If i sortsircuit the relay and touch the pins is flashing the diferent bulbs but there is no signal to amplifier from radio and when i remove my hand the bulbs go off. In this condition the amplifier produces a noise when i put a finger on the transistor.
    thanks anastasio
  • 01-01-2010 7:15 PM In reply to
    • Dillen
    • Posts 5,008
    There can be many reasons for this behavior.
    Aging capacitors and wrong wattage lamps to name a few. Kits are available for both
    but in your case I think, I would check the functionality of the electronic switch and especially
    the little IC9.
    Check also for cracked solder joints at the large output stage transistors.
  • 01-02-2010 1:55 AM In reply to
    Martin  the 3 bulbs on bass treble and balanse were dead plus 1 on volume.
    what if i take some bulbs from fm fm1 2 3 ?Which ones are important?
    Output is ok, no solder problem. I am going to check the ic later
    anastasio
