1st March February 2012
Latest post 01-08-2010 12:09 PM by k984942. 15 replies.
01-01-2010 11:43 AM
Donemi
- Joined on 07-03-2009
- Posts 6
I wonder if anyone can help me with this issue? I have recently connected a FOXSAT HDR to my BV9 and would like to add a SPDIF cable from the FOXSAT system to the BV9. However the FOXSAT system takes a Toslink connection to its SPDIF socket and the BV9 appears to take a jack type connector to its SPDIF socket. Does anyone know if there exists an adaptor to convert the Toslink connection in order that I can connect it to the BV9.
Appeciate help
Happy new year
ouverture
- Joined on 04-20-2007
- London
- Posts 282
Re: SPDIF Connection on BV9
which model Avant do you have ?
did they fit Digital Coaxial inputs on all the Avant TV's ??
I cannot find it on my Avant :-(
Toubro
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 263
ouverture:
I have a 32" RF DVD model. I don't know if all Avant has this, but mine has 2 digital inputs, one for the V.Tape Scart socket and one for the AV Scart socket. They are located next to the Powerlink sockets.
Donemi
- Posts 6
Thanks for this information, I had originally assumed that it would only require an adaptor, but now realise that the signal also needs to be changed.
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
ouverture:
If you have a 93xx type, then it is possible to place a Dolby Digital module (with 2.4 software it will be also DTS) instead of the Dolby Surround module.
This DD module is the one with three socket's, Front, Sub and Rear.
If you're planning to replace the board, be carefull! There has also to be made a slight adjustment on the chassis, which is very important!
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
How can I tell which software version my Avant has?
I go to the 'Monitor Information' page but I can see several entries in there beginning 'SW' so am unsure of which one I should be looking at.
Whenever I play a DVD via my DVD1 the Avant display says 'Dobly Digital'
I have never seen it say 'DTS'
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
Beobuddy
- Posts 1,582
In monitor information you have to search for something like `32 IC607 (DSM) ver 1.9`
If you´re having 1.9 then you have probably the latest software for the DolbyD module.
If you will replace it with 2.2 or higher from the other DTS boards, then you have the DTS functionality.
But keep in mind, if you´re having the 1.9 version, this supports 2 channel PCM as the 2.4 doesn´t.
If you have the DTS module, then it will only be displayed shortly in the display where normaly the clock is displayed, as for Dolby Digital it is always displayed next to the clock.
k984942
- London, UK
- Posts 194
Thanks for your help Beobuddy.
I have version 1.4.
I guess this means I only have Dolby Digital?
Is there any other functions I could be missing out on by having this software version? If yes, is it a hardware or software upgrade to take me to the latest (2.4?) SW version?
I LOVE my Avant so would like to make it the best it can be while its still alive!
Beobuddy
- Posts 1,582
Just replace the 1.4 with the latest 2.4 version abd you have DD and DTS.
I´ve done this with my brother´s avant for a few month´s ago. He had the 1.9 software.
As I told, It all has to do with the codec´s the module has to deal with.
Just order the software which is used in a RF (DVD) version with DTS.
k984942
- London, UK
- Posts 194
Don't quite understand Beobuddy.
What is an abd?
Would appreciate it if you could dumb it down for me a bit!
Are you saying I need to replace some of the hardware or is it simply a software update. If it is software, do I need B&O to come over with a laptop or can I do it myself?
Also, if I do get my Avant up to version 2.4, are there any other benefits other than having DTS sound?
Beobuddy
- Posts 1,582
First of all, I assume you have a Dolby Digital module in your Avant, so the software of the avant doesn´t have to be upgraded.
Then, on the back of the avant there is the module, which has a (hardware)chip. It is easy to locate it and rather easy to do it yourself.
The benefit of DTS is better sound. DTS has for instance less compression on the rear channels. Lots of DVD´s has a special DTS track included. The difference can be heard easily.
But no more benefits then the DTS sound.
But the upgrade doesn´t cost much, so I think it´s worth every penny/euro.
Beobuddy
- Posts 1,582
k984942:
Sorry, just has to be `and` .
k984942
- London, UK
- Posts 194
Ahh....I understand now! Thanks Beobuddy.
I do indeed have the Dolby Digital module.
I upgraded the STB-B IC myself inside the Avant (was an old one with all outdated STBs)
Is this module you speak of essentially the same, ie a little chip that simply plugs in inside - no special tools, no soldering etc?
If so, any idea of the cost and part number?
Thanks for all your help
Beobuddy
- Posts 1,582
It is basically the same as changing the ic on the STB, only easier!
You don't even have to take the chassis from it's position.
Remove the 2 screws on both sides of the module and remove the flatcable. Then it is rather easy to change the ic.
Costs are probably around the 55 euro (just found the invoice) for the chip itself.
k984942
- London, UK
- Posts 194
Brilliant!
Thanks a lot Beobuddy!
Page 1 of 1 (16 items)
