Latest post 06-16-2007 7:46 PM by tborgeest. 4 replies.
Page 1 of 1 (5 items)
  • 06-15-2007 9:11 PM
    Beovox/Beolab Penta Speakers - Replacement Grille Cloth
    I have a pair of both Beovox and Beolab Penta speakers and the grille cloth on both pairs is starting to deteriorate. I have spoken to the local B&O dealer and he says replacement cloth or the grilles are longer available. Does anyone know if and where it is possible to source the original fabric - I don't need the grilles - just the cloth.
  • 06-16-2007 12:09 AM In reply to
    Re: Beovox/Beolab Penta Speakers - Replacement Grille Cloth
    The frets are definitely still available because I have just bought some. Your dealer has not tried hard enough!
    The part number is 3450714 for a set of 2 frets for one speaker.
    Regards Graham
  • 06-16-2007 3:03 AM In reply to
    Chris recovered his in a blue material - and very good they looked too!
  • 06-16-2007 7:44 PM In reply to
    Hi Graham
    Thanks for this - I live in Australia so I'll pursue the dealer again or contact B&O direct
    Cheers Terry
  • 06-16-2007 7:46 PM In reply to
    Thanks for the response - I am trying to keep them as original as possible so I'll pursue Graham's response
    Cheers Terry
