Latest post 12-30-2009 2:42 PM by Wulf. 2 replies.
Page 1 of 1 (3 items)
  • 12-30-2009 4:18 AM
    • Wulf
    • Not Ranked
    • Joined on 07-15-2009
    • Posts 8
    Slide Show with Background Music
    Hello All
    Is there the possibility to run a slide show (pics are on BM5) and having music playing in the background (using the mp3's on BM5) at the same time?
    Thanks for any idea and a happy new year!
    Wulf
  • 12-30-2009 9:39 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Slide Show with Background Music
    Sure. Press PC to start your BM5 and BV. You will get the main menu. Select N.MUSIC - music starts up. Press MENU and select PHOTO. Press MENU - 3 (slideshow). Now you listen to N.MUSIC and watch photos from your BM5.
    Hope this helps.
    Stefan
  • 12-30-2009 2:42 PM In reply to
    • Wulf
    • Not Ranked
    • Posts 8
    Thank you for the quick answer Stefan. Sometimes life is easy Smile
