Latest post 01-04-2010 8:34 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 12-30-2009 2:05 AM
    • dkkoo
    • Not Ranked
    • Joined on 01-05-2009
    • Posts 8
    Hello!! Hope you had a lot of fun in Christmas.
    I know this isn't general PUC thread but there's nowhere else I can ask for help.
    I created a PUC for a Sharp Aquos LCD tv. but there's somthing worng and
    showed an error "could not get global list for decoder Sharp AQUOS" in the STMKII
    When I made the file, I modified the existing sharp screen puc by
    simply swapping the original IR data to what I've captured from the Aquos remote.
    As, it  uses sharp protocol, I captured it in a row format(decimal) then converted it to hex.
    I browsed other puc files and there's some PUCs using raw fomat.
    It really causing me a headache, please help me !!
  • 12-30-2009 2:53 AM In reply to
    • dkkoo
    • Not Ranked
    • Posts 8
    Re: Need help - PUC file
    I was not careful enough when I write the raw code.
    I guess it was too long(96flanks)
    Now, I have shorten it by removing repeated code,(now 64 flanks)
    and finally successed to make a table for Aquos.
    I haven't tested it yet but hope it woks fine
  • 12-31-2009 3:06 AM In reply to
    • dkkoo
    • Not Ranked
    • Posts 8
    I've uploaded the new file
    Not yet tested on the real AQUOS
    but verified the signal from BS3 is identical to the original remote
    Happy New Year
  • 01-04-2010 8:34 AM In reply to
    I am pleased you managed to modify the PUC file, quite a complex process..
    Regards Keith....
