Latest post 01-02-2010 8:44 AM by koning. 8 replies.
Page 1 of 1 (9 items)
  • 12-29-2009 10:49 AM
    • Reox
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 31
    BeoSound 9000 problem
    Hi all,
    I wonder if anyone can help?
    I have a BeoSound 9000 connected to an Avant and speakers.
    After a recent power cut I found myself having to re-enter
    the pin code for the Beosound 9000. Unfortunately, due to
    being a pillock, I didn't enter this correctly the first
    2 or possibly 3 times.
    I then checked the pin code and entered it correctly the
    third time (I think) and everything seemed fine.
    However the next day my set-up is starting up and functioning
    as normal for a few minutes but then turning itself off, whether
    it's on TV, radio or CD.
    I'm not given the opportunity to re-enter the correct pin code
    for the BeoSound 9000, even after leaving it in standby for
    4 hours or disconnecting the whole system over night.
    I should add:
    If I disconnect the BeoSound 9000 the TV works as normal
    and doesn't switch itself off.
    When in standby the BeoSound 9000 makes an intermittent
    clicking noise every few minutes (similar to the one it normally
    makes when being switched on).
    Any suggestions on how to fix this problem gratefully received.
  • 12-29-2009 11:01 AM In reply to
    Re: BeoSound 9000 problem
    Hmmm... I have the same setup.
    I don't think that the pin code is the issue here??? It seems you did get it right and the BS9000 awoke.
    My guess would be to keep it simple. Put everything in standby, remove power, reboot and input the code again.
    Anyone else?
    ++++EDIT++++ I just re-read your post... It sounds like you did disconnect (does that mean from power?) the system? Just the 9000, or everything?
    • B&o bottle opener
  • 12-29-2009 11:11 AM In reply to
    • Reox
    • Not Ranked
    • Posts 31
    Hi burantek,
    Thanks for your input.
    I have tried putting the whole system in standby over night.
    I have tried unplugging the whole system from the wall over night.
    I have tried disconnecting the BeoSound 9000 from everything else for a few days.
    None of these options is getting a positive result unfortunately.
  • 12-29-2009 11:20 AM In reply to
    Reox:
    Well, then you'll have to go beyond simple!
    Hopefully someone will be along with more technical ideas...
    Masterlink line (ports) took a surge when the power went DOWN/UP???
    • B&o bottle opener
  • 12-29-2009 11:33 AM In reply to
    • Reox
    • Not Ranked
    • Posts 31
    Possibly, but I don't know if that would result in everything
    still working perfectly, albeit for only a few minutes at a time.
    Everything is connected via a surge protection multi-socket adapter,
    but I don't know how effective they are.
  • 12-31-2009 12:55 PM In reply to
    Try cleaning the i.r. prisms (2 clear plastic bits under the glass), the aluminium and the glass inside & out. If they get dirty they can cause some very  strange problems.
    Good Luck
  • 01-01-2010 6:20 AM In reply to
    I had the same problem......micro processor dead.
    275 euro poorerSad
  • 01-02-2010 4:32 AM In reply to
    • Reox
    • Not Ranked
    • Posts 31
    Thanks sgresswell. I tried cleaning the lens's to no avail unfortunately.
    Thanks for the information koning. Was your microprocessor problem
    the result of a power cut/power surge?
    Is it so difficult to have in-built protection against power surges
    in electronic equipment? All the other electronic equipment in the house,
    including 4 computers, is fine and that's all plugged directly into the mains.
    How do I prevent this happening again given I already had a power surge
    'protected' multi-socket adapter fitted to my B&O set-up? I won't necessarilly
    be around/awake to unplug it.
  • 01-02-2010 8:44 AM In reply to
    I turned the power in and of a couple of 10 times.
    ignored the pincode
    The next day when I turned the power on, the bs9000 goes in standby.
    DEAD...Sad
