given that BS2 is likely to have a secondary cell; does it require a replacement after a gap of 3 years or so.
the problem that i am facing is that my player does not retain charge.
despite the player been on the docking station for ~ 2-3 hrs the blinking green light would not return to a constant green.
given the above is it conclusive that the battery needs a replacement - if yes can you please indicate approx charges towards getting it serviced from B&o
