1st March February 2012
Latest post 12-30-2009 3:49 PM by Bv7Mk3. 8 replies.
12-28-2009 7:48 PM
GuyHui
- Joined on 03-17-2007
- Posts 1,560
How to clean the BL8000 black "stand"
Hello,
I have some difficulty to have my BL8000's stands cleaned. In fact, dust is getting in the black stands and tends to solidify.
I have tried to clean them using a hot humid sponge, but after an hour, a white calcareous layer appears on the surface. It is very hard to remove that.
Do you think that applying a wet sponge with demineralized water will do the trick.
Thanks for your help !
Cheers,
Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
Hungedu
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
Re: How to clean the BL8000 black "stand"
Try mixing in a little lemon juice or carbonated water. The slight amount of citric or carbonic acid may break up the calcium deposits.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
It's going to sound odd, but tire-shine does very well cleaning them and restoring them to their obsidian luster as though fresh from the box. I keep one of the little squeezey ones with the built-in sponge in the store at all times.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
GuyHui
- Posts 1,560
Thanks for your advice.
According to the tire-shine solution, will it break the calcium deposit as if we were using carbonated water ?
Cheers,
Guy
TripEnglish
- America
- Posts 1,595
GuyHui :
Cheers,
Guy
In my experience it does, though I've only dealt with mild deposits. If not, maybe try a solution to remove calcium deposits and then do the tire shine to bring out luster.
GuyHui
- Posts 1,560
Thanks for your feedback,
Guy
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
When we get BeoLab 8000's like this we detach them from the speaker, clean and scrub them in hot soapy water, rough them up with wire wool then re-spray them with satin black car bumper paint. We use bumper paint as it's slightly rubberised, can take knocks, and never flakes off.
If i was looking to restore the lustre on original unpainted ones, use silicone dressing spray heavily then leave it to soak in overnight. Buff off with a microfiber the next morning and they'll look fine.
Lee
GuyHui
- Posts 1,560
Thanks Lee for your help.
Guy
Bv7Mk3
- Joined on 12-01-2007
- Posts 272
A little bit of shoe polish dapped on the base,then buffed up with a brush is another way.
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
Page 1 of 1 (9 items)
