Hi all
I've been searching the forum for a while, but haven't found all the answers I'm looking for. Thought it'd be quicker just to ask!
1. First off, is there any real pressing reason that I should buy the MkIV new, considering it's likely to be around £3k more? As far as I've found from searching, the picture isn't significantly better - and the addition of Bluray doesn't interest me that much, especially considering the mode of operation from the Beo4! I have a PS3 on the rare occasion I actually want to watch a Bluray. I like the idea of saving my cash now, and upgrading to the latest and greatest when it really is significantly better!
2. I know most Beovisions have a sort of 'auto-aspect' adjustment feature on SCART inputs (e.g. when a 4:3 picture is playing, the screen shows it in a 15:9 box and cuts some of the top and bottom off). Does this operate on the BV7/BS3's HDMI inputs as well? My parents' have the BV7-32, and it doesn't operate this on the DVI input (nor does Format 1/2/3 make any difference to the picture shown).
3. In a similar vein, do the HDMI inputs allow for the PUC menu overlay when you hit menu? Again, on my parents' 32, Sky HD on DVI will just show the Brightness/Color/Contrast menu instead.
4. If anyone's using Sky HD - what are you using to get the Dolby Digital signal from the box to the TV? The HD box only outputs DD from the optical output, and there is no optical input on the BV7. An optical->coax S/PDIF converter?
5. Are any of the HDMI sockets taken up internally on the MkIII, like on the MkIV? I have 3 HDMI sources at the moment, and if I were to buy a Beosound5 at any point, I would assume I would need a 4th.
Thanks in advance. Think that's enough for now, though I'm sure I'll think of some more!
Charlie
