1st March February 2012
Latest post 12-27-2009 5:25 PM by mfirst. 12 replies.
12-26-2009 3:24 AM
jho4evah
- Joined on 12-26-2009
- Posts 3
I'm having a look at new headphones, as I want to move up from the headphones included with my Zune 30. I've decided after looking at the design and specifications of headphones in the price range I have to get the A8's or Form 2's. However, I'm not sure which ones would be more suitable. So I have a couple of questions.
1. What have better bass reproduction? 2. What is the warranty like, as in if something happens what would be the procedure?
And just a general overview of the headphones in general compared to each other would be great.
Thanks for you help.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Toubro:
My brother have had the form 2's for an eternity and I don't like them. The square shape of the speaker part just doesn't feel right on my ear. The A8's are my favourite headphones and I have had these for 9 years. I had them changed once, as the plastic parts in the bottom of the part that goes behind your ear broke off. B&O gave me a new pair, no questions asked.
I'm sure you soundwise can find a better pair for the same price, but I love my A8's
I agree the A8's are better than the Form 2's. I would also add however that they aren't brilliantly comfortable if you wear glasses and that the sound isolation is quite poor - if you intend using them for travelling etc. I find in ear types to be much better for listening to your music while keeping the background out.
I used to wear my A8's in the office too, while working, and they are a bit of a faff if you need to keep taking them off and refitting - the in ear types are easier for that too.
All this may sound quite anti, but I do prefer the sound of my A8's to my Form 1's and would happliy listen to them at home where it's (hopefully) quiet and I won't be needing to remove them at regular intervals.
For out and about-ness however, I now prefer in-ear types ................ Sennheiser CX550's are quite good.
Puncher
- Posts 9,588
Peter :
A8s used to have a problem with the cord but any so affected were always simply replaced by B&O with no questions. The newer ones are less likely to be affected. Agree with Puncher - you need to try them on to see that they are comfortable. I use mine a lot as does my daughter. She has Form 2s for her computer and uses these a lot as well. I have better headphones for home use though - Sennheisser HD600 and Grado RS-1.
To Peter's point, when I say "listen at home" I mean to my iPod, I wouldn't propose A8's as your main headphones if you listen a lot to your system at home. I would agree with him the the HD600's are the best headphones I've heard (I've never listened to the Grados).
Interestingly (for UK member anyway) I notice Currys has installed a heaphone listening facility in some of their stores where you can compare several headphone from the same source. I would bank on the "hifi-ness" of the setup but I was amazed to see some HD600's last time I was there - I didn't think Currys went that far "up the tree", so to speak. Anyhoo, you have to be a fool to buy them there as they were charging full RRP!
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
Having both Form 2 and A8s, from a purely functional point of view, I would suggest using the Form 2 at home and A8s on the go.
The Form 2 is extremely fragile, bulky and inadequate for outdoor use, whereas you can go anywhere with the A8s on your head, they won't drop, and when not in use, you can put them safely in their leather pouch, they weigh only 8 grams and not 68 gr, and you don't have to rearrange your hair after each album..
Reunion Island is greeting you!
wirralsimon
- Joined on 04-17-2007
- Birkenhead, UK
- Posts 1,253
The Form 2 is probably only for someone who must have B&O at all costs!
I would say go for the A8's or possibly the Sennheiser PX100 or PX200 which are available here in the UK at most 'Department Store' outlets alongside the Bose, Apple etc.
Simon
mfirst
- Joined on 04-21-2007
- Posts 155
wait a minute!
I had a pair of A8's and wanted very much to like them - but Hated them!
These types of in the ear sets (like the ones supplied with ipods, etc) only fit certain types of ears.
For the vast majority of people, they fit great - but they dont fit (actually the problem is that they dont stay in my ears at all - always falling out)
Try them first to see if they fit your ears - if so, then ok - but if they dont fit well (like in my case) it will drive you crazy.
Finally sold them on ebay.
Beautiful ear pieces, but not for me - I guess I could get plastic surgery.......
-michael
Page 1 of 1 (13 items)
