Latest post 12-25-2009 9:00 AM by Webu. 5 replies.
Page 1 of 1 (6 items)
  • 12-24-2009 2:33 PM
    • Webu
    • Not Ranked
    • Joined on 12-07-2008
    • Finland
    • Posts 21
    • Gold Member
    BeoMaster 4400 channel balance
    Christmas greetings,
    Yesterday I was turning up the volume a bit on the BM4400 when something happened: the balance seemd to get more on the right speaker and bass response kind of smoother on the lower end (sounds pretty nice though). I had to set the balance slider to -2 to make it sound quite balanced again - has anyone experience such a thing before?
    I've done the Dillen's cap and trimmer kit last summer, so they should be alright - but might there be something else ageing or possibly in need of a little inspection?
    Kind regards, Jouni
  • 12-24-2009 4:20 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: BeoMaster 4400 channel balance
    I have no experience on 4400 but I have a BM3000 which can't be that much different. Usually the switches on the front panel get oxidized and cause one channel to mute or go down in volume. In my BM3000 I found especially the MONO L / R, LOW / HIGH FILTER and LOUDNESS switches to cause lost channels. Does the 4400 have a TEST -switch at the rear panel? That have caused me troubles as well.
    Season greetings from not-so-far-away Yes -  thumbs up
    Bang & Olufsen - The art of controlling sound, picture and light
  • 12-24-2009 4:24 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I agree on the switches. Especially the ones that are only rarely used. Work them all a bit.
    Swap the speakers first to make sure that the problem is not with one of them.
  • 12-25-2009 7:30 AM In reply to
    • Webu
    • Not Ranked
    • Finland
    • Posts 21
    • Gold Member
    Many thanks for your replies Smile
    Hmm, I tried going through the switches a bit, but I couldn't really notice anything this time - also moving to the second speaker outputs sounded pretty identical to me (first time by the way) Unsure But yes, swapping the left and right channels does make a difference - it sounds more balanced and better having them reversed Stick out tongue
    I've got to admit that I might be a bit confused by myself now as well, but shouldn't that mean one of the channels is getting more power than the other one? Would I be able to measure the output with a multimeter just to be sure?
    My current speaker placement isn't too optimal - that's why I'm scared if there used to be a slight problem with the other channel which just got normalized again, but I'm thinking it the wrong way now as I might already got used to it before Indifferent
    Regards, Jouni
  • 12-25-2009 8:30 AM In reply to
    • Dillen
    • Posts 5,008
    A signal generator and a power (watt-)meter would be nice.
    I use B&O TG7 and RWM4 but others will work just as well.
    A multimeter on AC volts put across the speaker output and a steady and continous
    test signal of f.e. 1KHz sinewave on an input will surely be adequate
    to at least give you an idea.
  • 12-25-2009 9:00 AM In reply to
    • Webu
    • Not Ranked
    • Finland
    • Posts 21
    • Gold Member
    Oh yes!
    The multimeter test showed 0.044V for the left channel and 0.054V for the right channel playing a 1kHz sine wave MP3 with volume at 1, balance at 0 and loudness on. I used an old 2-3m speaker cable to meter though, but of course that shouldn't have any effect when I just move the connector between the channels.
    I've got to set the balance slider to around -1,1 or -1,2 to get them both at 0.044V - hmm.. Let me try with different frequencies and a bit higher volume as well Huh?
    Edit: Well most interestingly noticed that pushing down the mono switch makes the difference like half smaller - otherwise different frequencies and volumes were acting quite much as you could supposed, as well as loudness and linear switches (loudness seemd to have a very minor effect on the lower frequency balance though, but nothing more than that apart from the normal level boost).
