Latest post 01-06-2010 9:16 AM by Keith Saunders. 8 replies.
Page 1 of 1 (9 items)
  • 12-24-2009 12:49 AM
    Download BEO5 Config Tool v3.23
    Hi Guys
    A little Chistmasgift. You can download the BEO5 Config tool v3.23 here: http://www.megaupload.com/?d=90Y55ZZW
    Merry Christmas
    /Frank
  • 12-25-2009 6:41 PM In reply to
    • BOMF
    • Not Ranked
    • Joined on 12-12-2009
    • Lausanne
    • Posts 26
    Re: Download BEO5 Config Tool v3.23
    Thanks a lot Frank.
    I wish you a Merry Christmas and Happy New Year ! Smile
    BOMF
  • 01-05-2010 12:24 PM In reply to
    Hi.
    What login and password should I use?
    Regards
    Magnus
  • 01-05-2010 12:48 PM In reply to
    You don't! Just use it offline - the log in is for a dealer log in and password. Not necessary for programming.
  • 01-05-2010 12:50 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Does someone have a changelog of this new version? We lack of changelog for every B&O product, in order to know what software version helps for one's precise problems...
  • 01-05-2010 2:49 PM In reply to
    mbee:
    There is a changelog in the built into the opening screen of the tool on the right hand side.
    Cheers,
    Frank
  • 01-06-2010 4:57 AM In reply to
    beo4me:
    Not when you are using it in "Off Line" mode
    Regards Keith....
  • 01-06-2010 7:15 AM In reply to
    Keith Saunders:
    beo4me:
    You mean there is more than this in online mode?
    Cheers,
    Frank
  • 01-06-2010 9:16 AM In reply to
    Yes, that is exactly what I am saying.
    What you are seeing here are the updates that were made prior to the Installation file being produced. When dealers login they receive updates which are appended to the list. If you are not a dealer and use it off line, then that update notice will never change.
    Regards Keith....
