Latest post 12-24-2009 10:13 AM by Rapidroy. 8 replies.
Page 1 of 1 (9 items)
  • 12-22-2009 9:05 PM
    Beocenter 2200 stuck in "NEXT" mode
    Hi All
    Well I  got the belts for the cass. deck installed them but it seem the Beocenter 2200 is stuck in the "next" mode on the keyboard or switch board. the deck won't do a thing. Anyone have any ideas?
    Roy Albuquerque, NM
  • 12-23-2009 2:14 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2200 stuck in "NEXT" mode
    Does the cassettedeck motor run ?
    The capstan ?
  • 12-23-2009 10:27 AM In reply to
    Hi Martin
    I got the belts, Thanks. If I hold the play button down the motor spins, If I mess with it I can get the heads to move up and down when the gears spin. but I think theres something up with the "next" button (not really the button but the circuit) , the light is on all the time.
    Roy Albuquerque, NM
  • 12-23-2009 10:57 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    I've had many of these types of problems in older cassette decks. The problem is that the rubber on the idler wheels has hardened and is too smooth.
    Assuming you can find new replacement idler tyres, rather use new.
    Assuming not (my experience), first soften the rubber with an alcohol-soaked tissue held to the rubber wheels, while they are turning.
    After the rubber softens (you will see that the tissue is not blackening from the rubber any more, take a Japanese knife, and hold the blade to the rubber (while turning) shaving off a miniscule layer of the old rubber.
    Reapply alcohol.
    You should see an improvement in the function of the deck.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 12-23-2009 12:47 PM In reply to
    • Dillen
    • Posts 5,008
    Are you sure you got all three belts on correctly ?
    The square belt next to the flat belt can often cause confusion.
  • 12-23-2009 3:54 PM In reply to
    I'll post a picture  when I get home from work. I think I have them right. The square one rides on the outside of the brass motor pully (right side)
    Roy Albuquerque, NM
  • 12-23-2009 11:51 PM In reply to
    Here's a pic
    Roy Albuquerque, NM
  • 12-24-2009 4:11 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, that looks fine.
  • 12-24-2009 10:13 AM In reply to
    any Ideas on why its stuck on "next" if not I'll ebay it for parts. I'm thinking I need to reset a chip or something.
    Roy Albuquerque, NM
