Latest post 12-31-2009 11:52 AM by yachadm. 4 replies.
Page 1 of 1 (5 items)
  • 12-22-2009 4:33 PM
    Beogram 5500 problem
    Hi!
    I am a newcomer to this forum, hoping for help with my Beogram 5500.
    I recently unpacked a Beosystem 5500 that had been stowed away for a few years. Everything works fine, apart from the record deck.
    It doesn't react when i push the "turn", "lift", "play" or "stand by" buttons. When I press any of these buttons it just gives a soft buzzing sound for a few seconds, but then nothing happens.
    When pressing the "play" button, the numbers telling what speed the turntable is turning at lights for a few seconds and then disappears.
    The turntable itself starts spinning as soon as the power cord is connected, and won't stop until I pull it out.
    It doesn't react to any commands from the MCP either.
    Anyone got any idea about what could be wrong?
    Thankful for any help.
    /Dan, Stockholm, Sweden
    Filed under:
  • 12-23-2009 5:43 AM In reply to
    Re: Beogram 5500 problem
    Hello Dan. Welcome to Beoworld!
    It sounds like a electronic failure. I am afraid that it could be difficult to fix. I have also had a 5500, it is a fine machine, and such failure is quite rare I think. I just don't know that much about these decks.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 12-23-2009 6:22 AM In reply to
    I believe this to be an electronic fault on the pcb. The last one that I saw which exhibited the same fault was cured by my fitting a replacement board from a cosmetically challenged turntable which I scrapped.
    Regards Graham
  • 12-24-2009 4:42 PM In reply to
    Cheers. Since I'm no good with repairing electronics myself it seems like I'd better start exploring the used B&O turntables market. Anyone got any idea what a Beogram 5500 might cost?
  • 12-31-2009 11:52 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Check this thread:
    http://forum.beoworld.org/forums/p/28461/225759.aspx#225759
    I developed this home-made non-electronic solution, for this common problem in this entire series of B&O turntables - you should have lots of patience to do it. If it is this problem, looking for a parts turntable won't help you - there's a good chance that the parts unit will have this same problem as well.
    And if all else fails, send me your PCB for a rebuild.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
