i do have some troubles with my masterlink system.
Recently my house was directly hit by a lightning. At that time a Beosound 9000 was connected via one single masterlink Cable to an Avant.
The Beosound 9000 had a major breakdown, most of the electronics needed to be replaced. The Avant seems to be fine.
After the return of the Beosound 9000 i want to enhance the masterlink.
I connect Beosound 9000 to BeoLab 2000 using Cable A, it works.
I can do the same using a different Cable B, also fine.
When i do the cabling like Beosound 9000 via Cable A to Masterlink Distributor via Cable B to Beolab 2000, it won't work.
If i connect Beosound 9000 via Cable A or Cable B directly or with the Distributor with the Avant, it doesn't work. It also does not work, if i connect the Beolab 2000 with the Avant.
The Masterlink Distributor is brandnew from the dealer, also is cable A. Cable B was used in the installation already before the lightning.
How can i test, which parts work and which not? Could it be that the masterlink Connector within the Avant is damaged? How could i test this? And why does a conenction via a Masterlink Distributor not work?
Any hints?
Merry Christmas,
Kiwi4all
