Hi, was wondering if one of you experts could help me. I see there have been a lot of developments in regards of making an Appletv work with older TV´s without composite connectors. Ive written this request after reading up in advance on this site and other about connecting an Appletv to TV without these connectors and quite frankly Im even more confused now than I was before.
Some say that you can use a cable with composite on one end and scart on the other, others say you cant, some say you can use a composite cable to S-VHS connector.
And others say none of these will work as you have to have a convertor connected to a set of composite cables then connect a scart cable to the tv. As the convertor will change the signal into RGB.
Can someone please help this confused APPLETV purchaser who has no idea what way to connect it to my B and O Avant 32 inche Scart TV. Also information on where I can get, whatever I need to do this will be of great help.
PS please be aware although the TV is a VHS B and O I dont actually use the VHS anymore so if needed can use any connection the the VHS player would of used.
