Latest post 12-20-2009 5:48 AM by mbee. 3 replies.
Page 1 of 1 (4 items)
  • 12-19-2009 2:31 PM
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    BV8 40 : PUC not working
    I have a strange problem with my BV8 40 : everything worked fine until last week, when my girlfriend (alone at home with the BV8 while I'm away...) said that the PUC is not working anymore to control our satellite receiver (Sagem ISD 91HD). I cannot check anything as I'm away until next week, but the PUC cable is connected to the TV and it's still glued on the Sagem. On the PUC list, it seems that it's still the same peripheral selected...
    The Sagem is still responding to its own remote, so the problem doesn't come from here.
    So before calling my dealer (who has to come anyway, in order to update the TV software to the latest version), I want to know if someone here has any clue on what I could do to solve the problem...
  • 12-19-2009 3:28 PM In reply to
    • stefan
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BV8 40 : PUC not working
    The first thing I would check is whether the IR transmitter works. Maybe it`s faulty. You can see the IR commands when you look at the IR transmitter through a digital camera or mobile phone. While watching the IR transmitter you must send commands via Beo4.
    Next thing reset the AV port settings in the connections menu to NONE and save. Now set the settings again as before.
    Hope this helps.
    Stefan
  • 12-20-2009 3:13 AM In reply to
    Switch the whole thing off at the mains and then back on again - cures a multitude of sins!
  • 12-20-2009 5:48 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    @stefan : I will check that as soon as I come back...
    @Peter : the TV is switched off from the mains everynight!
