Russ and others-
I apologize. I'm so clueless about B&O I probably shouldn't even own one. (smile) As far as the Model Designation, I'm not sure where to find that. This is the information I do have from the tag under the control panel: Type#: 2571; Serial#: 15922769; and Item#: 125009. I very much hope this helps answer my initial question. Thanks a bunch in advance. -Phil
