Latest post 12-17-2009 4:43 PM by JC. 3 replies.
Page 1 of 1 (4 items)
  • 12-17-2009 1:04 PM
    Wall mounting Beolab 3500
    Hello folks, First post on here.
    Can anyone help with wall mounting the Beolab 3500 link speaker? I have just bought one from eBay and it has no wall bracket, - only a grey plastic bracket, which I can't believe will take the weight. - Also there are no apparent screwholes.
    If anyone has any PICTURES of the mounting and any tips to get it right, as I'll be struggling with it overhead trying to get it straight and secure before my arms give up!
    Thanks!
    (sorry if this post appears twice - 1st attempt using Google Chrome didn't appear to work..)
    • Beosound 3000 (NMUSIC)
    • Beolab 4000
    • Beolink Active w/Beovox 3800 Surprise
    • Beolab 2000
    • Beolab 3500
    • Beolink PC-2
    Filed under:
  • 12-17-2009 2:39 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Wall mounting Beolab 3500
    Seems lik you are missing the (metal) bracket
  • 12-17-2009 3:20 PM In reply to
    Thanks Gerd. - I'll contact my dealer and see if I can get this part.
    • Beolab 4000
    • Beolab 2000
    • Beolab 3500
    • Beolink PC-2
  • 12-17-2009 4:43 PM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    It is available Christian so you are OK. I do not understand how the sellers loose this part or omit to send it.
      Jonnie
