Hi Beoworld!
I recently I bought a defective beomaster 8000, which I thought I could get up and running. But I ran into some problems.
When plugged in, it would start in standby mode, and after 5-20 seconds slowly start to show random weak lights in the display (turning the tuning wheel would brighten up the display). After a cleaning of the connectors inside the master, the display now reads this when powered up:
0.0 0 00
0
The unit doesn't react to anything.
One of the reasons of this behavior is somewhere in the the 5V supply or the computerboard. All the voltages in the power supply seem to be correct if the microcomputerboard(9) is disconnected. But when the microcomputerboard is connected to the rest of the system, the 5V drops to 2,5 V.
After having spent quite some time trying to locate the fault, I would apreciate if anyone here on beoworld has an idea of where the problem could be.
Thank you
Søren
