Hi Peter,
I changed the configuration to "PACE Sky+" as my first guess too, but seems that the codes are actually changed (may be the newer receiver for Italy - with USB and LAN plugs to support IP-TV and DVB-T extensions) had different codes that the UK version - I know they are supposed to be different models from PACE.
I'm waiting for answer to the same question from my B&O Dealer; the SKY HD receiver is supported on newer TVs, but it has never installed on standard HD televisions. I upgraded because of the coaxial output for Dolby Digital, avoiding to but an optical -> coaxial converter as I did for my PS3. ;)
Thanks for your answer, I'll let you know just for reference.
Raffaele "SKApretto n.71" Sgherri
I like Chrome and spread it!
