Hi Carsten
Nice to hear it worked ( I knew that)
I ment if you dont want the embedding stuff, the folder.jpg must be located in the same directory as the album.
If you want to embed the coverart in the files, the filename do not have to be folder.jpg. You can b.t.w. delete the .jpg file after use.
Maybe if you already have succeded without the folder.jpg copying. My guess is that the coverart already was embedded in the files.
Greetings
Jobak
