Latest post 12-15-2009 5:15 AM by stefan. 11 replies.
Page 1 of 1 (12 items)
  • 12-13-2009 12:28 PM
    • BeoNut1
    • Top 500 Contributor
    • Joined on 08-19-2007
    • Mobile, AL (USA)
    • Posts 226
    Question for BV-7 owners
    When those of you who own a BV7 use the DVD/CD/Blu-ray player to play a CD, does the flat panel come on, or does the TV simply say "CD" and port the sound to speakers sans LCD turning on?
    TIA,
    Mark
    Mark D
  • 12-13-2009 12:31 PM In reply to
    • santi
    • Joined on 12-08-2007
    • Barcelona
    • Posts 170
    Re: Question for BV-7 owners
    Screen switches on but it goes off in a few seconds.
    Santi
  • 12-13-2009 12:39 PM In reply to
    • BeoNut1
    • Mobile, AL (USA)
    • Posts 226
    Santi,
    Thank you for your prompt response.
    When the CD/DVD/Blu-ray player is doing this, does the smaller screen say "CD" or does it say "DVD"?
    I'm trying to think of ways to keep the screen from turning on with music (i.e. to in essence make the BV-7 an audio "head" unit).  I wonder if I could somehow make an Apple TV be occassionally seen as an audio source by the BV-7 so as to avoid turning on the screen (and having to use "picture mute" to turn it off).  I'm controlling the Apple TV via an iPod Touch or iPhone so I don't need the Apple TV's on-screen-menus for listening to music.
    Mark
    Mark D
  • 12-13-2009 1:25 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Why not just pressing AV - DVD ? This will let the stand turn to audio position, switch to SPEAKER 2 mode and let the screen switch off.
    Stefan
  • 12-13-2009 1:53 PM In reply to
    • BeoNut1
    • Mobile, AL (USA)
    • Posts 226
    Stefan,
    If the screen was already off (let's say the entire TV was off with the red B&O light on), would hitting "AV-DVD" just turn the speakers on in Speaker 2 without having the screen ever turn on?
    Mark
    Mark D
  • 12-13-2009 4:00 PM In reply to
    • stefan
    • Posts 1,733
    Pressing AV - DVD while  BV7-40 is in standby mode, lets the stand turn to audio position, activate DVD player, switch on SPEAKER 2 mode.
    The screen does NOT turn on. Tested right now with my BV7-40 MKIII, SW 5.xx.
    Hope this helps
    Stefan
  • 12-13-2009 9:22 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Melbourne, Australia
    • Posts 445
    BeoNut1:
    I'm trying to think of ways to keep the screen from turning on with music (i.e. to in essence make the BV-7 an audio "head" unit).  I wonder if I could somehow make an Apple TV be occasionally seen as an audio source by the BV-7 so as to avoid turning on the screen (and having to use "picture mute" to turn it off).  I'm controlling the Apple TV via an iPod Touch or iPhone so I don't need the Apple TV's on-screen-menus for listening to music.
    If you have a BS9000 you can connect the Apple TV to the auxiliary port via a RCA to Din cable. Use a HDMI to DVI connector in the Apple TV hdmi port. Then select A.AUX on the Beo4. You will have music without the BV7 turning on its monitor.  Of course this will not work with digital audio out and its reliant on an auxilary port on a B&O CD system which acts as an audio master...
    Alternately buy a BEO5 and configure it to mute the picture when you press Apple TV.
    hope something here helps and Seasons Greetings.
    beoaus.
  • 12-13-2009 9:26 PM In reply to
    • beoaus
    • Posts 445
    stefan:
    Really, must try this myself... I thought all video sources need the screen on to start with... Do you know if this works with V.AUX, Camera etc?
    beoaus
  • 12-13-2009 10:18 PM In reply to
    Our Apple TV is connected to V. Tape. Tried AV-V. Tape and worked as described.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-13-2009 10:35 PM In reply to
    • BeoNut1
    • Mobile, AL (USA)
    • Posts 226
    That's good news as I'd really like to turn on the speakers without ever turning on the TV panel and letting the Apple TV act like a stereo (that's guided via WiFi and an iPod Touch).
    What do you guys think about this idea:  What would happen if I connected the Apple TV to two different ports on the BS3 of the BV7?  I'd designate one a video port and one an audio port and use the "audio" portion in the way that we've described above.  Do you think this would work?
    M
    Mark D
  • 12-13-2009 11:17 PM In reply to
    Seems like it would work. Also, might have an additional benefit if you have 5 speakers. We have our BV7 set to 5 speakers for Video, 2 for Audio. Thus when activating Apple TV as a Video Source all five speakers come on and I must use Speaker on the Beo 4 to switch to 2 speakers for music. If connected as an Audio source would go to 2 speakers automatically.
    If I remember correctly Apple TV only has one HDMI but could use HDMI and Analog connections. We have both connected. HDMI so we get video and audio in main room, analog so we can get audio in Link rooms.
  • 12-15-2009 5:15 AM In reply to
    • stefan
    • Posts 1,733
    beoaus:
    stefan:
    beoaus
    Yes, it also works with A.-V.AUX, but check if your Beo4 got A.-V.AUX in the list. There are older Beo4 versions, that don`t have this source.
    Should work with any video source.
    Stefan
