Latest post 06-17-2007 2:13 AM by auric. 4 replies.
Page 1 of 1 (5 items)
  • 06-14-2007 8:24 PM
    B&O Din Connector Pinout?
    Hi:
    I'd like to make a DIN to RCA adaptor so that I can plug in an additional source to the AUX of my B&O.
    Does anybody know the pinouts for  L,R and GND on the 5 pin DIN?
    Thanks,
    Derek
  • 06-15-2007 3:04 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: B&O Din Connector Pinout?
    Does this help?
    Beotech
  • 06-15-2007 3:29 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Hi Derek!The pins in a DIN-Connector should be numbered from 1 to 5 (on the plastic). The easyest to find is the "2", it is the pin in the middle which is ground of left and right together, then "5" = right = red wire and "3" = left = other color. The pins "1" and "4" are record out. If the pins are not numbered, you can find out the wanted, when you plug it in (just the plastic with the pins) and switch on AUX at low volume. Then touch the pins with a piece of wire, one after the other, it's not dangerous! When you hear a humming sound, that's the right. If you want to take care of your speakers, you can use a headset. Have fun! Chris
  • 06-15-2007 6:53 PM In reply to
    Thanks a bunch Chris!
  • 06-17-2007 2:13 AM In reply to
    Puncher: Just what I needed. Many thanks for the reply! Derek
