Latest post 12-10-2009 9:52 AM by kai. 3 replies.
Page 1 of 1 (4 items)
  • 12-09-2009 7:02 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Home Cinema
    HI GUYS
    I HAVE RECENTLY INSTALLED A HOME CINEMA SYSTEM CONSISTING OF BEOSYSTEM 3 WITH 100" PROJECTION SCREEN LUTRON LIGHTING SYSTEM AND LUTRON BLINDS ALL IS WORKING WELL, I HAVE BEEN ASKED BY ANOTHER CLIENT IF I COULD HELP FINISH A INSTALL, VERY SIMILAR TO THE ONE MENTIONED ABOVE, NO PROBLEMS IN SETTING UP THE EQUIPMENT BUT WHAT WOULD DO FOR THE PROJECTOR, WOULD YOU GO FOR THE RECOMMENDED BANG AND OLUFSEN SOLOUTION OR COULD YOU USE A 3RD PARTY SOLOUTION WHICH WOULD GIVE ME FULL CONTROL I.E WHEN I PRESS THE CINEMA BUTTON ON THE REMOTE WOULD IT ALL WORK. KAI
  • 12-09-2009 9:53 PM In reply to
    Re: Home Cinema
    http://forum.beoworld.org/forums/p/23397/175162.aspx#175162
    There were some issues with other projectors, there should be a ton of prior discussions on here.
    Cheers
    JK
  • 12-10-2009 2:30 AM In reply to
    Re: Home Cinema
    I use Panasonic PTA 3000E and it`s amazing picture
    And the new one PTA 4000E is even better they say
  • 12-10-2009 9:52 AM In reply to
    • kai
    • Posts 81
    Re: Home Cinema
    Hi ander-son
    What I'm trying to find out is, what projector can i use out of the box, which will work with the beosystem 3. The one that was used for another job was a JVC this was used with box of tricks supplied by a company from down south. What I need is something the customer can order up via the internet, and when I install it, it works out of the box, I know how to adjust the cinema timming, but I need to make sure when he hits the cinema button the screen and projector come down and the projector switches on, look forward to your reply
    Kai
