Latest post 12-11-2009 2:36 AM by Premiumverum. 6 replies.
Page 1 of 1 (7 items)
  • 12-09-2009 9:21 AM
    5-pin motor base and MX6000
    Hi all,
    Friend of mine just recieved a motor base he bought for his MX6000 TV. Problem is, the motor base has 5 pins, while the connector on the MX has 4. How's this? Are there different motor base systems used? And is the 5-pin motor base even compatible with the MX6000?
    I'm puzzled!Huh?
    Laughing
  • 12-09-2009 9:25 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Re: 5-pin motor base and MX6000
    Hi there
    As far as I know, the 5-pin motorbase is the one for the MX8000 (which uses a different chassi and therefore cannot use the older 4-pin motorbases). The MX7000 and MX6000 uses 4-pin motorbases.
    best regrads
    Christian
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 12-09-2009 9:42 AM In reply to
    Hi Christian,
    Thanks! I guess a different chassis means it's not possible to make them compatible by changing the plug and/or doing some rewiring?
    Sad
  • 12-09-2009 11:49 AM In reply to
    • Stoney3K
    • Top 500 Contributor
    • Joined on 10-26-2007
    • Eindhoven, NL
    • Posts 91
    • Silver Member
    The MX5500/MX6000 series uses a single (presumably digital) pin to transmit and receive stand data, which connects to the AV link bus inside te television set. (Service manual, p. 17).
    The MX8000 uses an analog system on the 5-pin DIN connector, with a feedback potentiometer to determine the stand position and two active low outputs to control the stand (MX8000 service manual, p.10), so the two wiring schemes are incompatible.
    You might be able to combine a stand control PCB from a dead -5000 or -6000 series PCB with the existing stand motor in the 8000 stand, since they run off the same 14V supply, that could work.
  • 12-09-2009 2:06 PM In reply to
    Thanks! I found a motor with 4-pin plug in a mean while, think I'll  just interchange them, the size and screws seem the same.
    Or find an MX8000, it seems like a nice TV to meWink
  • 12-09-2009 8:13 PM In reply to
    • sverreh
    • Joined on 04-17-2007
    • Norway
    • Posts 88
    If you want a 4 pin motor, I have one for spare and will be happy to swap with you?
    Sverre
  • 12-11-2009 2:36 AM In reply to
    Thanks Sverreh!
    I already found a replacement though, so no need no more Smile
