Thanks for your swift reply.
I have already ordered a 5 pin DIN to put onto the cable, or do you think its best to remove the whole lead and connect straight to the transformer?
I had thought the same about the glue, i will try it. The wiring around the stylus looks fine, or did you mean perhaps the internal wiring being the cause?
I heard the deck before i picked it up and it sounded very good and i transported it very carefully so i would hope that the fault didnt pick up in transit.
I suspected that you would say the lid should sit on the wood surround, i think i was just hoping it would be a simple adjustment of the lid!
I am fairly adept to repairing the basics of electronics although i do understand that these machines can be very complicated. I am based in London, so if you have an recommendations for someone to look at it? I have bought replacement belts from Barry in east london, do you know if he would be able to anything?
I dont really want to spend hundreds getting it back if i can do at least most by myself.
I will try to glue it tonight and will tell you how it goes
thanks
Tom
