Latest post 12-14-2009 3:25 PM by Jobak. 6 replies.
Page 1 of 1 (7 items)
  • 12-08-2009 9:31 AM
    only 9 song in the colored playlist
    I can only fit 9 songs in each colored playlist and not 99 as it says in the manual.
    Anyone has tried the same and knows what to do about it?
    'Thanks
  • 12-08-2009 12:56 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: only 9 song in the colored playlist
    Open up the "config" menu on BeoPlayer.  Select the "N.Music" tab, then select the "Favourites" tab.  This shows a screen where you can configure the limits for each colored playlist.  The default is 9.  Increase to whatever you like.
    Stan
  • 12-08-2009 1:50 PM In reply to
    Thanks,
    Is there any way you can do it on the BS5 - like in the service menu?
  • 12-09-2009 11:14 AM In reply to
    • Stan
    • Posts 593
    • Gold Member
    I don't think this restriction is limited by the BS5, just the BeoPlayer software.  I have a colored list with more than 9 songs that I created on the BS5 itself - although my BeoPlayer settings are still set to 9.
    I did create the list by dropping albums into the list, and there are probaby less than 9 albums, but when I look at the list on the BS5, it shows the songs, not the albums so there are definitely more than 9 items there.
    Stan
  • 12-10-2009 12:27 PM In reply to
    Have you tried to add more than 9 songs? Could you do it? I cannot add more than 9. It keeps pushing out the 'oldest'. This sucks.
    Anyone please help.
  • 12-11-2009 1:43 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    I tried this, and it works correctly.  I have a list that I added 30 songs to - I unchecked the "Limit Red list to" box in BeoPlayer.  I have another that I set to 20 and kept the "Limit" box checked and BeoPlayer allows 20 and then pushes out the oldest.
    What version of BeoPlayer are you using?
    Stan
  • 12-14-2009 3:25 PM In reply to
    • Jobak
    • Not Ranked
    • Joined on 11-17-2009
    • Posts 19
    Hi
    If you change the limit of items in coloured favorites in the N.Music config menu in Beoplayer. It will then copy this setting to BeoSound 5.
    jobak
