Latest post 12-05-2009 12:40 PM by Stan. 0 replies.
Page 1 of 1 (1 items)
  • 12-05-2009 12:40 PM
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Best way to remove/add a product?
    I bought a BS5 to replace my Beoport.  So far, I've been fine with using the BeoPort controls with the BS5.  I'm thinking about doing a proper programming, however.  I seem to recall warnings about not deleting equipment from a configuration file.  What would be the best approach to remove a BeoPort and add a BS5?  Make my BeoPort zone invisible?
    Does anybody have any feedback on whether this would add any value?  There's not much remote control available to the BS5, does a properly programmed Beo5 offer anything more?  I have been thinking I might at least add some icons for favorite N.Radio stations.
    Also, has the bug with macros that include 3rd party commands been fixed?  I am thinking that if I do this re-programming, I'd like to upgrade to current Beo5 software/firmware.  However, if I cannot do a macro that includes B&O and 3rd party commands, then I will not do this.
    Thanks in advance,
    Stan
