1st March February 2012
Latest post 12-05-2009 3:20 PM by Leslie. 9 replies.
12-05-2009 7:25 AM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
AC power cable part of wall mount Beolab 2500/Ouverture
Anybody who can help me with two AC power cords (approx. 51 & 69 cm used for connecting AC from Ouverture to one Beolab 2500 and the other from Beolab 2500 to the other Beolab speaker.
It has a male-female connector on each end. Can't find it in a local store and loose connectors are hard to find or else I would be able to make it myself. Any suggestions would be much appreciated!
Thanks in advance, Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Leslie
- Netherlands
- Posts 2,201
Re: AC power cable part of wall mount Beolab 2500/Ouverture
Not yet, thanks, but as a real Dutch citizen I can save money by making this cable myself or buying it cheap(er).
If I can buy loose male connectors somewhere than it would cost me probably about 3 euro's in total since I already have a lot of power cords at home that can be modified.
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi Leslie,
I tried to source the male connectors recently and was told by my supplier that they were now "banned" under EU laws, due to the "risk of electric shock from the exposed pins if used incorrectly"
Not sure if there is any truth in this, but I know they are hard to find outside of the official B&O route. I have always used a separate power cord for each speaker, rather than plugging via the outputs on the system....
Kind regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
I believe the regulation problem is with separate connectors - they have to be factory moulded to the cable to be legal.
I have some slimline fluorescent light fixtures that came with this kind of cables to allow daisy chaining them, so somebody (in China ) makes them. Don't think they were long enough for this purpose, though.
If it really needs to be just a single power cord coming out from behind the system, I'd build a small plastic junction box with a screw connector strip inside and snip the wrong end off regular power cords... with all due constructional precautions of course.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
705mm mains cable 6100231
510mm mains cable 6100216
Life is too short!!
Leslie
- Netherlands
- Posts 2,201
Thanks all for your kind support!
If this is true that these type of mains are banned by EU regulation than I wonder if my local dealer can supply them.
I presume that 705mm mains cable 6100231 & 510mm mains cable 6100216 are B&O part numbers?
Will check next week by my local dealer. Wonder what these will cost me since B&O is sometimes asking ridiculous prices.
Hope someone on this forum will have these as spare parts and is willing to sell for a fair price.
joeyboygolf
- Posts 3,252
The numbers are from the Beocenter 2300/2500 service manual which, as a gold member, you have access to.
I assume that it is not this type of mains cable that is frowned upon by the EU regulation, rather, the non moulded type of connectors that you are considering buying.
I presume that B&O cables are expensive because they DO conform to safety standards.
I may, of course, be talking through my rear end!!!
Leslie
- Netherlands
- Posts 2,201
Okay, that makes sense! Thanks!
Still, anyone who has these two cables somewehere in the closet?
Regards, Leslie
Leslie
- Netherlands
- Posts 2,201
Steve at Sounds Heavenly:
Kind regards,
Steve.
Hi Steve,
Have been thinking about you remark regarding the use of separate power cords. In this case I need 3 cords to power up the complete Ouverture system when mounted in a wall bracket instead of only one.
Thanks anyway for your response!
Page 1 of 1 (10 items)
