I have recently installed the Beo5 configurator (version 3.0.0.2). When connecting my new Beo5 to my laptop I'm getting the following info:
- Firmware version: 1.41a
- Hardware revision: 6
- Supported version: 0.39
My problem is as follows:
The configuration I have on my Beo5 is always the same even if I make a new configuration and I load it onto the Beo5. I 'm not getting any communication problem between my laptop and my Beo5; on the contrary I see that the configuration is loaded but when I check my Beo5 I notice that the existing configuration is always there.
