elephant: I will try this with V-AUX2
Well I have discovered the first limitation of my BV8 ... no V-AUX2 support; so I robbed V-AUX from my Foxtel and did some testing.
But it was nice to experience having the iTunes Visualiser on the BV8's screen while flipping between songs and playlists.
One surprise from the tests was my recent iTunes LP purchases, their "liner notes" content does not "play" when iTunes steps through the playlist.
I was using the "Recently Added" playlist, so all the songs in the LP played, but the associated visual content did not play.
The issue appears to be iTunes as the "liner notes" content is not ticked [√] in the playlist, not can it be activated with a "tick", it requires selection by a mouse (and then double click or the "play").
And I tried to see if it was possible to construct an "LP" only playlist ... no such luck, there appears to be no discrete meta-data that identifies this content as being of a unique type requiring special handling ... ah well, roll on iTunes 10?
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
