Latest post 12-04-2009 3:28 AM by MikaelB. 1 replies.
Page 1 of 1 (2 items)
  • 12-03-2009 5:16 PM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    BV740 MKI or II
    Are there numbers indicating when the model was changed?  Something on the back of the TV for instance etc?
    Are there any noteable differences?
    Thanks, beoaus.
  • 12-04-2009 3:28 AM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    Re: BV740 MKI or II
    The most noteable chage is the display in the front in the upper right corner.
    It changed from red to white (light blue), I beleive it was from Mk III.
    Otherwise the 4 digit modelnumber should be an indicator. Not sure what they are though.
    /MikaelB
