Latest post 12-17-2009 6:03 AM by solderon29. 1 replies.
Page 1 of 1 (2 items)
  • 12-03-2009 11:28 AM
    Problems with Beovision 7702
    Hi all first post, and asking for some help.
    I have aquired a 7702 recently, and it seems to work well, other than I can't make it switch to AV input.
    It will autoswitch to AV if connected to my DVD player, but won't auto switch when using a Playstation.
    Is there any way to switch it manually??
    Lewis
  • 12-17-2009 6:03 AM In reply to
    Re: Problems with Beovision 7702
    Is it a daft question,but have you tried pressing the 0 button.?From memory,that accesses av manually.
    Does your set have twin av inputs,ie Scart and 6 pin din?
