Latest post 12-04-2009 3:28 PM by beo4me. 2 replies.
Page 1 of 1 (3 items)
  • 12-02-2009 7:38 AM
    • fishta
    • Not Ranked
    • Joined on 02-12-2009
    • London
    • Posts 79
    BeoSound 5 and Windows Vista
    Hi Guys,
    I have trawled the forum and have yet to find anything on the problem I am having, I am trying to get BeoPlayer installed correctly on a Windows Vista PC to transfer to the BeoSound 5 however as soon as I click N.Music on BeoPlayer on the laptop it appears to "crash" so I really dont know what to do. I have tried unistalling, reinstalling, repairing and all with no avail so now turn to you guys for HELLLLLLP!!
    Any responses appreciated!!
    BeoVision 7-40 MkV
  • 12-02-2009 11:51 AM In reply to
    Re: BeoSound 5 and Windows Vista
    It should run under Vista without any problem ..
    Maybe try to run Beoplayer  in XP compatible mode
    (right mouse key on the beoplayer tab in start menu, go to properties and then select compatibility)
    did you install all patches for Vista ? If it is  an official release, then you can update via explorer.
    Of course it is a Microsoft OS ... So you need to reinstall from time to time to get it stable again. I'm using beoplayer also in Vista SP2 but with VMWare on MAC osX and this runs fine
    nico
  • 12-04-2009 3:28 PM In reply to
    I remember that there are some rights issues. Threre was some discussion some time back over in the PC forum. The nmusic exe file needs to have proper rights to run.
    Cheers,
    Frank
