Latest post 12-02-2009 5:12 AM by Toubro. 3 replies.
Page 1 of 1 (4 items)
  • 12-01-2009 8:56 PM
    Beolabs turning on/off.... harmful?
    Since I connected my BL8K/2 to my new pre-amp all is good.
    However, whenever I mute or pause the sound for a bit - the speakers will turn off (yes, I know part of how they work)
    Is this constant on/off bad for them?
    Is there a way that I can prevent them from going off even if there is no audio signal going to them?
    -michael
  • 12-02-2009 3:34 AM In reply to
    Re: Beolabs turning on/off.... harmful?
    Working as designed, so it should be safe. Not much you can do about it externally, except just turning down the volume instead of muting.
    I guess it would be just a change of a couple of components in the autostart circuit to alter the time constant for automatic off, but I'm sure it's not worth the trouble.
    -mika
  • 12-02-2009 5:04 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Not a techie, but I would suggest that it is good for them to keep switching on and off. A regularly used solenoid/switch/relay is less likely to carbon up. Just a thought.
    Andy T.
    Poor me, never win owt!
  • 12-02-2009 5:12 AM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    Which pre-amp is it?? Some pre-amps have "trigger outputs" which is often 12V. This can easily be converted to 5V, which is, (if I remember correctly), the voltage that Beolabs receive in the Powerlink cables to tell them whether they are on or off.
    If this is possible, the speakers should turn on/off with the pre-amp, instead of the sound.
