Latest post 12-10-2009 11:14 AM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 11-30-2009 8:04 PM
    loose record deck lid on beocenter 7700
    Hi all,
    The record deck lid on my Beocenter 7700 is coming loose , on inspection it looks like they used double sided tape to secure it originally.
    does anyone know a good make to fix this permanently. also one of the led sections is failing ( its comes and goes) and is very annoying as  unit
    is mint and fully functioning, so it would be nice to get these probs sorted
    thanks
    Justin
    Filed under:
  • 12-01-2009 9:21 PM In reply to
    Re: loose record deck lid on beocenter 7700
    just a quick update. the led has come back to life!! so fingers crossed it will stay that way. I think moving the 7700 from another house upset it a
    bit.
    Still needing advice on best glue/double sided tape to secure the record deck lid . any advice  gratefully accepted!!
    best
    Justin
  • 12-02-2009 2:36 AM In reply to
    Do you have a photo?
    ciao ciao
    Eugenio Colazzo
  • 12-06-2009 12:34 PM In reply to
    sorry for the delay , will try to photograph this tomoroow.
    thanks for the reply
    Justin
  • 12-06-2009 2:00 PM In reply to
    Ok we'll be here tomorrow to see the shot Big Smile
    ciao ciao
    Eugenio Colazzo
  • 12-09-2009 8:32 AM In reply to
    Cant make head or tale of  how you add photos to the site !!!
    Justin
  • 12-10-2009 11:14 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    justinlinnane:
    Justin
    To add a photo click on the "options" tab at the top left of the reply box then add/update to browse for a photo. Then click on "add" to download. Click back on "compose" to continue typing if you need.
    Chris.
