1st March February 2012
Latest post 11-30-2009 3:18 PM by Griebel. 10 replies.
11-28-2009 1:59 PM
Griebel
- Joined on 03-09-2008
- Posts 122
Bad quality picture of integrated blu-ray in BV7-40
Hello,
I just got a brand new BeoVision 7-40 with integrated blu-ray driver. I was badly surprised when I realized that the quality of the blu-ray picture of the integrated driver was not as good as the picture of an external blu-ray apparatus (Sony BPS-500). In fact the picture quality is just a bit above a regular DVD!
Did anyone have the same issue?
I'm wondering if I'm not going to exchange my BV7-40 with BRD for a BV7-40 without BRD (4000€ cheaper!) and keep my Sony BPS-500.
Guy
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Re: Bad quality picture of integrated blu-ray in BV7-40
Is this really the case? For 4000e one would imagine the BR player to be of very high quality.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Griebel
- Posts 122
Note that on a Mark IV the picture quality of an external blu-ray player is just perfect, unlike the quality of the integrated blu-ray player of the same TV, which is just a bit better than a regular DVD.
I really don't understand how a 4000€ blu-ray player has such a bad quality picture!!!
bayerische
- Helsinki, Finland
- Posts 3,593
I would give it back if the difference is that obvious. Maybe yours is faulty?
-Andreas
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Griebel:
It doesn't, I can guarantee it :) I'm not saying the internal Blu-ray drive is better than, say, a PS3-based Blu-ray picture, but it's certainly no worse.
However....are you sure it's not a HDMI issue? The stupid 'internal' drive uses one of the HDMI sockets to show a HD picture. If there is a problem with the allocation of this HDMI socket, you see an image through the internal scart-type cable. ie. Blu-ray is downgraded as if it was going through a scart cable. It's still slightly better than an SD DVD, but not much!
I know this from experience - if I mess up my HDMI allocation when configuring the Sky HD box on my BV7-40 MKIV, the picture goes via the scart cable instead and it's inferior. Although it's not a 'bad' picture, it's definitely worse than via the HDMI cable.
I'd assume this is your situation - it's now showing Blu-ray via the HDMI cable. Either it's disconnected or not configured correctly.
Griebel
- Posts 122
Very good point!
I will check this tomorrow and let you know if it was an HDMI issue, which led to a downgradation to a scart.
Guy
Griebel
- Posts 122
I feel stupid... because the HDMI cable of the internal blu-ray player was indeed disconnected when the TV was installed. The picture is now of blu-ray quality.
Thanks a lot for the advice!
Case is closed!
bayerische
- Helsinki, Finland
- Posts 3,593
Griebel:
Case is closed!
Good that you got it solved!
-Andreas
mawheele
- Joined on 12-05-2007
- Posts 82
Hi there - Can I ask how did you resolve this? When I check mine in the connections menu the DVD line is greyed out. Is there a way of knowing through the menus whether this is done correctly or not?
Appreciate your help.
Griebel
- Posts 122
Well I just reconnected the HDMI cable to the internal plug. No need to go into a menu. The DVD is by default greyed out.
Page 1 of 1 (11 items)
