Latest post 03-08-2010 2:00 PM by BerndE. 3 replies.
Page 1 of 1 (4 items)
  • 11-28-2009 12:02 PM
    • BerndE
    • Not Ranked
    • Joined on 05-12-2007
    • Munich
    • Posts 10
    MX4000 Picture with black stripes
    Hello Beoworlders,
    a few weeks ago my MX4000 (model 7870 from 1998) started to have black stripes and shadows in the picture. The stripes are not always visible, so it seems to be a slack joint or a dying component. This is how the picture looks like:
    A soft knocking on the top of the black back cover of the TV solves the problem, but the stripes come back after a few minutes.
    The stripes also appear in teletext and external AV sources.
    I have seen the MX4000 workshop (http://forum.beoworld.org/forums/p/24571/191760.aspx#191760), but i am not sure if my problem is related to the fixes in the workshop.
    Thanks for any tips
    Bernd
  • 11-28-2009 2:19 PM In reply to
    Re: MX4000 Picture with black stripes
    Looks like a problem on the vertical deflection ... most probably that 2.2uF cap in the drive line.
  • 01-30-2010 6:06 AM In reply to
    • Trigi
    • Not Ranked
    • Joined on 01-29-2010
    • Ry, Denmark
    • Posts 21
    • Gold Member
    Hi
    Replacing the caps C131 and C134 , 470uf 16v use to solve this problem.
    Best regards
    Trigi
    (Denmark)
  • 03-08-2010 2:00 PM In reply to
    • BerndE
    • Not Ranked
    • Munich
    • Posts 10
    I finally found some time to recap the mainboard as described in the MX Workshop. A complete success Smile
    The problems with the picture are gone and I'd say the picture is now as good as new.
    A good source for the low ESR caps is the Low ESR Shop.
    Bernd
