I have...
A 9000 CD player, 2 x Lab4500 wall mounted panels (front speakers), 2 x Lab 4000 (back speakers) and a lab 2
They are all plugged into an Avant TV that is starting to fail... So I am looking at options!!!
The best B&O options are to buy either a Vision 10 or 7-40 to replace the Avant - a simple swap over...
The other option is to hook everything into a decent Surround Sound amplifier that can support active speakers...
DOES ANYONE KNOW WHICH MANUFACTURERS DO THIS? I understand DENON have variable line out for each channel?
One issue I am aware of is that the Lab 2 needs a power line to switch it on (it does not sense the line in signal) - Is this currect?
Also - As the Lab 4500's only have link sockets I assume I will need to convert them to phono (RCA)...
Any ideas or advice would be most welcome...
